pihole after update not blocking anything
lease follow the below template, it will help us to help you!
Replace this text with what you think should be happening. Please include as much detail relevant to your system/install as possible including, but not limited to:
  • Operating System (Family and Version)
  • Hardware
  • Docker compose file or Docker run command
  • Docker engine version
pihole updated, after that it does not block anything.
it was running for about half year no problems, still seem to run perfect just ain’t blocking anything.
is there something changed in the software that needs to be adjusted ?
FSU3jSQt
Yes lots and lots:
Your debug log shows you disabled the Default group (enabled=0 means disabled):
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0        0     Default                                             2024-06-15 19:30:10  2025-05-01 16:45:24  The default group
Since this is the only group you have, all rules are also disabled and Pi-hole won't block.
Solution:
Enable the Default group.
thank you very much for the link. I there also a document or manual for those new functions have been searching a long while now. especially for the new items in the pi-hole.
thank you very much for you help, it works. never done anything with groups don’t really understood the benefit of more groups, so always left it the way it was. thank you so much and have a great day.
Its on the same link under the "ABOUT" pulldown :wink:
