Pihole admin interface inaccessible
I installed pihole on a raspberry pi 5 and cannot access the admin interface. I figured this is because I have nginx proxy manager installed on the pi which is occupying port 80. after reading multiple posts on this forum I edited the lighttpd.conf port number to 8080 and tried accessing it that way with no success. I also tried changing it to port 8888 without success. I reinstalled pihole and did not select the option to install web server and it is working to block ads. however I would like to be able to use the admin GUI so if anyone has a solution that might help I would greatly appreciate it.
Please create a debug log and post the token URL it gives you here.
here is the token URL:
https://tricorder.pi-hole.net/BWrTAxms/
Which URL are you using to access the web interface?
What do you see when you try http://192.168.8.213:8888/admin?
:woman_facepalming: I wasn't putting /admin at the end of the URL. Working fine now! thanks so much!
