is their a place to find beta6/development-v6 changelogs per build? when i click the links on the bottom of pihole where it says update available it brings me to version 5.
They are running the merges for v6.0 nightly, and so I don't expect them to maintain a daily changelog. Perhaps there is some clever way in GitHub (or in a developer studio program) to see how the merges make the code evolve over time. I would recommend looking at the pull requests in GitHub to see what's coming.
cool thanks... as far as github works i can only git clone.... but if its under commits then that "update is complete" and will be pushed to the nightly update?
Correct. If you want, you can also build the docker image locally by cloning the repo and running something like:
docker buildx build src/. --tag [whatever you like] --no-cache
And then instead of pihole/pihole:development-v6
, just refer to whatever you tagged the image as
the build idea is awesome.
can you tell me why this is not working
pihole6:
build:
context: $DOCKER_DIR/builds/pihole6
dockerfile: Dockerfile
args:
GIT_URL: https://github.com/pi-hole/docker-pi-hole
GIT_REF: development-v6
container_name: pihole6
hostname: pihole6
networks:
mynet:
ipv4_address: '172.23.0.253'
ports:
- "53:53/tcp"
- "53:53/udp"
environment:
TZ: 'America/New_York'
FTLCONF_dns_dnssec: 'True'
PIHOLE_UID: 1000
PIHOLE_GID: 1000
DNSMASQ_USER: pihole
FTLCONF_dns_upstreams: 'cloudflared#5054'
FTLCONF_webserver_api_temp_unit: 'F'
VIRTUAL_HOST: 'pihole6.example.dev'
SKIPGRAVITYONBOOT: 1
volumes:
- '$DOCKER_DIR/pihole6:/etc/pihole'
- '$DOCKER_DIR/pihole6/log:/var/log/pihole'
restart: unless-stopped
im getting
[+] Building 0.1s (2/2) FINISHED docker:default
=> [pihole6 internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [pihole6 internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 2B 0.0s
failed to solve: failed to read dockerfile: open /var/lib/docker/tmp/buildkit-mount2109097490/Dockerfile: no such file or directory
The dockerfile is located at ./src/Dockerfile
git clone -b development-v6 https://github.com/pi-hole/docker-pi-hole.git .
[+] Building 0.3s (15/15) FINISHED docker:default
=> => transferring dockerfile: 2.93kB 0.0s
=> [pihole6 internal] load metadata for docker.io/library/alpine:3.18 0.2s
=> [pihole6 1/9] FROM docker.io/library/alpine:3.18@sha256:eece025e432126ce23f223450a0326fbebde39cdf496a85d8c016 0.1s
=> => resolve docker.io/library/alpine:3.18@sha256:eece025e432126ce23f223450a0326fbebde39cdf496a85d8c016293fc851 0.1s
=> CANCELED [pihole6] https://raw.githubusercontent.com/pi-hole/PADD/PADD_FTLv6/padd.sh 0.0s
=> [pihole6 internal] load build context 0.0s
=> CANCELED [pihole6] https://ftl.pi-hole.net/macvendor.db 0.0s
=> CACHED [pihole6 2/9] RUN apk add --no-cache bash bind-tools binutils coreutils curl g 0.0s
=> CACHED [pihole6 3/9] ADD https://ftl.pi-hole.net/macvendor.db /macvendor.db 0.0s
=> CACHED [pihole6 4/9] COPY crontab.txt /crontab.txt 0.0s
=> CACHED [pihole6 5/9] ADD --chmod=0755 https://raw.githubusercontent.com/pi-hole/PADD/PADD_FTLv6/padd.sh /usr/ 0.0s
=> CACHED [pihole6 6/9] RUN git clone --depth 1 --single-branch --branch development-v6 https://github.com/pi-ho 0.0s
=> CACHED [pihole6 7/9] RUN cd /etc/.pihole && install -Dm755 -d /opt/pihole && install -Dm755 -t /opt/p 0.0s
=> CACHED [pihole6 8/9] COPY --chmod=0755 bash_functions.sh /usr/bin/bash_functions.sh 0.0s
=> ERROR [pihole6 9/9] COPY --chmod=0755 start.sh /usr/bin/start.sh 0.0s
> [pihole6 9/9] COPY --chmod=0755 start.sh /usr/bin/start.sh:
failed to solve: failed to compute cache key: failed to calculate checksum of ref 13a2a7c5-5849-44b3-9a0d-4723501a1400::xgsk0ceoghr2ueojhgykraml7: "/start.sh": not found
maybe ill just wait for your builds lol
What if you just run this command in the directory?
i got it with docker compose but i had to copy everything in src to the root folder.
edit:
winner winner chicken dinner
pihole6:
build:
context: $DOCKER_DIR/builds/pihole6/src
dockerfile: $DOCKER_DIR/builds/pihole6/src/Dockerfile
args:
GIT_URL: https://github.com/pi-hole/docker-pi-hole.git
image: build_pihole6
still have to manually git pull the database though
To anyone who's curious found how to build it on demand straight from github with docker compose
pihole6:
build:
context: https://github.com/pi-hole/docker-pi-hole.git#development-v6:/src
no_cache: true
add all your volumes, env, ports, ect like you would normally
docker compose up -d --build
edit: added no_cache so it pull fresh everytime.
That's a pretty neat trick
Here is the specification for using a repo for the build context:
Information current as of 2023-10-15T07:00:00Z
Git repositories
When you pass a URL pointing to the location of a Git repository as an argument to docker build
, the builder uses the repository as the build context.
The builder performs a shallow clone of the repository, downloading only the HEAD commit, not the entire history.
The builder recursively clones the repository and any submodules it contains.
$ docker build https://github.com/user/myrepo.git
By default, the builder clones the latest commit on the default branch of the repository that you specify.
URL fragments
You can append URL fragments to the Git repository address to make the builder clone a specific branch, tag, and subdirectory of a repository.
The format of the URL fragment is #ref:dir
, where:
ref
is the name of the branch, tag, or remote referencedir
is a subdirectory inside the repository
For example, the following command uses the container
branch, and the docker
subdirectory in that branch, as the build context:
$ docker build https://github.com/user/myrepo.git#container:docker
The following table represents all the valid suffixes with their build contexts:
Build Syntax Suffix | Commit Used | Build Context Used |
myrepo.git |
refs/heads/<default branch> |
myrepo.git#mytag |
refs/tags/mytag |
myrepo.git#mybranch |
refs/heads/mybranch |
myrepo.git#pull/42/head |
refs/pull/42/head |
myrepo.git#:myfolder |
/myfolder |
myrepo.git#master:myfolder |
refs/heads/master |
/myfolder |
myrepo.git#mytag:myfolder |
refs/tags/mytag |
/myfolder |
myrepo.git#mybranch:myfolder |
/myfolder |
does the github page update in sync with the docker hub? Or are commits immediate? I just pulled a fresh image and it says I still need to update
Pi-hole version is development-v6 96640ea (Latest: N/A)
web version is development-v6 6c3d45c (Latest: N/A)
FTL version is development-v6 vDev-78a424b (Latest: N/A)
You see a different issue here. Pi-hole failed to retrieve the latest versions from GitHub (yet). So the hash of the latest commit is empty and therefore different than the hash of the current local commit. The web interface interprets this as an available update. The fix will be part of Tweak and fix the update footer by yubiuser · Pull Request #2745 · pi-hole/web · GitHub
For now, try running pihole updatechecker
within the container.
maybe this has to do with my github links not being able to resolv during the docker compose process. my dns is 127.0.0.1 for the container. is their an env variable to use loopback that i am missing. I also set the interface to accept on all.
from only the container itself i cant resolv dns its nameserver is 127.0.0.11 but if i change it to 127.0.0.1 in /etc/resolv everything is working.
❯ pihole updatechecker
fatal: unable to access 'GitHub - pi-hole/pi-hole: A black hole for Internet advertisements': Could not resolve host: github.com
fatal: unable to access 'GitHub - pi-hole/web: Pi-hole Dashboard for stats and more': Could not resolve host: github.com
fatal: unable to access 'GitHub - pi-hole/FTL: The Pi-hole FTL engine': Could not resolve host: github.com
You could try to set an external DNS server for the container in the compose file
