I have installed Pihole on the latest version of Raspbian on a Pi zero W. After running for between an hour and 10 hours, the Rpi hangs. The power light is on but I cannot access the Pi using a keyboard, ssh or the web interface. The install of the OS and the Pihole software is completely standard.
I have changed the SD card and the Rpi board and the problem continues. I have tried increasing the swap file size but again the doesn't help. I have tried changing the power supply (both standard RPI "official" adapters. and again this make no difference. I have tried installing the Pihole software at least 4 times.
I have installed Pihole in exactly the same way on a Rpi 4 and the system works perfectly.
Any suggestion on how I can resolve this issue would be gratefully received.
I think the following might be relevent.
**** Extract from the syslog file: *******
Feb 20 14:40:01 rpiz1 CRON[18244]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Feb 20 14:50:01 rpiz1 CRON[20221]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Feb 20 14:50:06 rpiz1 dhcpcd[505]: wlan0: hardware address 00:00:00:00:00:00 claims 192.168.0.63
Feb 20 14:50:08 rpiz1 dhcpcd[505]: wlan0: hardware address 00:00:00:00:00:00 claims 192.168.0.63
Feb 20 14:50:08 rpiz1 dhcpcd[505]: wlan0: 10 second defence failed for 192.168.0.63
Feb 20 14:50:08 rpiz1 avahi-daemon[256]: Withdrawing address record for 192.168.0.63 on wlan0.
Feb 20 14:50:08 rpiz1 avahi-daemon[256]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.63.
Feb 20 14:50:08 rpiz1 dhcpcd[505]: wlan0: deleting route to 192.168.0.0/24
Feb 20 14:50:08 rpiz1 dhcpcd[505]: wlan0: deleting default route via 192.168.0.1
Feb 20 14:50:08 rpiz1 avahi-daemon[256]: Interface wlan0.IPv4 no longer relevant for mDNS.
Feb 20 14:50:08 rpiz1 systemd[1]: dhcpcd.service: Main process exited, code=killed, status=11/SEGV
Feb 20 14:50:09 rpiz1 avahi-daemon[256]: Interface wlan0.IPv6 no longer relevant for mDNS.
Feb 20 14:50:09 rpiz1 avahi-daemon[256]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fdaa:bbcc:ddee:0:14c6:546:fd47:c5cd.
Feb 20 14:50:09 rpiz1 avahi-daemon[256]: Withdrawing address record for fdaa:bbcc:ddee:0:14c6:546:fd47:c5cd on wlan0.
Feb 20 14:50:09 rpiz1 systemd[1]: dhcpcd.service: Failed with result 'signal'.
********* End ***********
That the Pihole should work for extended periods with out issues
The RPI hangs appears to hang after an unspecified period
