Pi suddenly stopped working
One fine day, my PiHole enabled RPi suddenly stopped working.
Here are the details
  • PiHole on 192.168.0.200
  • It works as a DHCP server giving out IP addresses to other devices on the network
  • My router's DLink DIR 825AC is configured to "DHCP Relay" and the ip address matches that of the RPi
  • My router's only DNS server is 192.168.0.200
I didn't change any settings - and it has been working fine (just like this) for a long time.
But suddenly, I couldn't access anything on the Internet. The only fix was to change my routers DNS to 1.1.1.1 (i.e. move away from using the RPi as a DNS lookup server)
I tried to generate a debug token. But that wouldn't upload. So here it is --> https://pastebin.com/xJ6KsTY4
I also tried to update to the latest, but that didn't work either:
  [✓] Detected ARM-hf architecture (armv6 or lower) Using ARM binary
  Error: Unable to get latest release location from GitHub
  [✗] FTL Engine not installed
I'd really appreciate some help.
With this exception, the software has been excellent and very very stable. I'm full of appreciation for all the devs behind this. Thank you.
You have DNSSEC enabled and some of your domain queries are coming back as BOGUS, which may indicate a problem with DNSSEC authentication.
Check that the time on your Pi is correct for your location: date
If not correct, you can reset your time with this command: timedatectl set-time '2015-11-20 16:14:50'
where you would substitute the correct date and time in that format
If you find that the time is off and you reset it, then restart FTL with sudo service pihole-FTL restart
Yes, the time is off.
It is being measured in UTC, and it is off by around 3.5hrs.
I tried to update it, but there is an error:
rpi@raspberrypi:~ $ timedatectl set-time '2019-06-05 11:46:20'
Failed to set time: Automatic time synchronization is enabled
Anything else that I could try?
Also, a couple of questions
  • Why doesn't just resetting the pi solve the problem?
  • Is this also the reason that pihole -up is not working?
  • Is this the reason why I'm getting an error uploading a log?
  • Why might have this happened? I didn't change a thing
Thanks!
http://www.itsprings.co.in/linux/Failed-to-set-timeAutomatic-time-synchronization-i
The Pi does not have a built-in clock, so it depends on external time servers for accurate time.
Probably yes, with DNSSEC enabled. If the time is off, the authentication mechanism won't work and the DNS replies can be rejected as BOGUS.
If your Pi lost power suddenly, this can cause time problems.
Fixed, thank you!
  • The time out-of-sync was the issue
  • To fix it I had to disable auto setting of date time with timedatectl set-ntp false and then manually set the UTC time
  • After this I restarted the sync with timedatectl set-ntp yes - but I could never figure out why the NTP sync wasn't working. The timedatectl said NTP-synchronized: No
  • Anyway, it wasn't perfect but it allowed pihole -up to function. And after that, everything seems fine. And NTP is synchronized.
Probably chicken egg dilemma.
The ntpd daemon is configured with domain names:
pi@noads:~ $ cat /etc/ntp.conf
pool 0.debian.pool.ntp.org iburst
pool 1.debian.pool.ntp.org iburst
pool 2.debian.pool.ntp.org iburst
pool 3.debian.pool.ntp.org iburst
And pihole-FTL is only able to resolve them to IP, via DNSSEC, if time set by ntpd is correct.
A possible solution would have been to configure ntpd with IP addresses instead of those pools making ntpd independent of DNS resolution.
pi@noads:~ $ host 0.debian.pool.ntp.org
0.debian.pool.ntp.org has address 109.236.82.30
0.debian.pool.ntp.org has address 95.211.212.5
0.debian.pool.ntp.org has address 80.100.130.235
0.debian.pool.ntp.org has address 149.210.142.45
pi@noads:~ $ sudo ntpdate -u 109.236.82.30
 8 Jun 23:19:20 ntpdate[9447]: adjust time server 109.236.82.30 offset -0.001288 sec
No DNS needed to sync and plenty of ntp servers to choose from if query for the other default configured ntp pools :wink:
host uses DNS to find the IP address.
Thats not what I meant.
Use host to lookup as many IP addresses as you desire and put them in the ntp.conf file on a server line (hash out the default pool ones oc).
EDIT: eg.
server 95.211.212.5
server 80.100.130.235
server 149.210.142.45
Sorry, I noticed current distro's with systemd use below one for time sync instead of old fashion ntpd:
$ man systemd-timesyncd.service
DESCRIPTION
       systemd-timesyncd is a system service that may be used to
       synchronize the local system clock with a remote Network Time
       Protocol server. It also saves the local time to disk every time
       the clock has been synchronized and uses this to possibly
       advance the system realtime clock on subsequent reboots to
       ensure it monotonically advances even if the system lacks a
       battery-buffered RTC chip.
If want to know if systemd-timesyncd is active:
$ sudo service systemd-timesyncd status
● systemd-timesyncd.service - Network Time Synchronization
   Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled
  Drop-In: /lib/systemd/system/systemd-timesyncd.service.d
           └─disable-with-time-daemon.conf
   Active: active (running) since Mon 2019-06-03 07:50:04 CEST; 3 weeks 0
If want to check if its configured to sync:
$ timedatectl
 Network time on: yes
NTP synchronized: yes
 RTC in local TZ: no
NTP servers need to be configured here on the "NTP=" line:
$ cat /etc/systemd/timesyncd.conf
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See timesyncd.conf(5) for details.
[Time]
#NTP=
#FallbackNTP=0.debian.pool.ntp.org 1.debian.pool.ntp.org 2.debian.pool.ntp.org 3.debian.pool.ntp.org
Eg.
NTP=109.236.82.30 95.211.212.5 80.100.130.235 149.210.142.45
EDIT: Ow and for the record, if you still have ntpd installed (apt policy ntp), below one is holding systemd-timesyncd back:
pi@noads:~ $ cat /lib/systemd/system/systemd-timesyncd.service.d/disable-with-time-daemon.conf
[Unit]
# don't run timesyncd if we have another NTP daemon installed
ConditionFileIsExecutable=!/usr/sbin/ntpd
ConditionFileIsExecutable=!/usr/sbin/openntpd
ConditionFileIsExecutable=!/usr/sbin/chronyd
ConditionFileIsExecutable=!/usr/sbin/VBoxService
To switch:
sudo service ntp stop
sudo apt remove ntp
sudo service systemd-timesyncd restart
timedatectl
Thank you for this, I didn't know this service existed, however I do NOT agree with your statement old fashion 'ntpd'. The man page of systemd-timesyncd itself says: This minimalistic service will set the system clock, which might be sufficient for most users, the more robust implementation of the NTP deamon might still prove to be of value, and makes life consistent for people managing more than a single Linux system, systems that don't always have the systemd-timesyncd service.
The systemd-timesyncd service is an SNTP client, only implementing the client part of NTP. If you want to use your pihole as the source to go for time (NTP server), this will NOT be possible.
The systemd-timesyncd service, according to the manual, writes to tour SD card, every time the clock has been synchronized, NOT one of my favorites to read, I rather spend the 8$ for a new SD card (mentioned in some other topic) on something else, but that's a personal point of view.
Thank you again for pointing out the existence of this, running out of the box, but unconfigured service
If somebody decides to go for the NTP daemon instead of the systemd-timesyncd service, here is how to clean up, avoiding the service to run but do nothing (as you explained earlier)
sudo service systemd-timesyncd stop
sudo systemctl disable systemd-timesyncd
Yeah I do not agree with allot of the SBC distros getting bloated with software you might not want.
I would prefer a really minimalistic install and if I need time sync or some network manager/mangler, I'll choose to install which one.
But they try to make it a bit non Linux user friendly which is fine with me but still I would prefer a really minimalistic install.
You dont have to disable the systemd-timesyncd daemon.
It wont start if any of below NTP daemons is installed:
[Unit]
