I understand. Figured I would let you guys know. I was trying to look it over, but it was not showing the images and still isn’t, even when the cdn and website domains being whitelisted.
I do use Brave browser, but I have the shield disabled on your website. I will look into this more and see, but I am not sure what else I can do on my end, but I am willing to try testing more things.
I have also disabled the pi hole for 30 seconds to test the website out, and I still had the same issues. I will test the website in Firefox and see if it works.
I can confirm this is me with the problem. I wonder if this is brave, doing it? Hubby has Chrome, and it works for him, and we are both using the same pi-hole.
Firefox tries to fetch the 768x768 version, which returns a 404.
In Chrome, a different size is selected and displays fine.
When resizing the browser window size, the 300x300 version loads correctly.
Looks like the 768x768 variant might be missing or not generated on the server.
Yeah... apparently the theme, or some plugin or config is generating code to load 768x768 images, but they don't exist. This is not a big issue if some image is shown.
Currently there is nothing I can do about it because I don't have access to the website theme. Probably @DanSchaper or @PromoFaux will need to check the images.
Honestly, I'm surprised when I see an order come in for the shop. It's in quite a messy state right now and I haven't had time to essentially redo the entire setup.
I placed an order, bought two mugs, but I won’t lie, it was not a pleasant experience. But I pushed through to help support your project. And the images are still broken. What tsutsu3 said is also true for Chromium users.
I checked my Firefox settings and found that the default zoom level was set to 110%.
When I reduced it to 100% or lower, the image displayed correctly.
The same issue occurred in Chrome — the image doesn’t show up when the zoom level is above 100%.
Do you use Brave at all? And did you test this on the Brave browser? I know for me, no matter the size, I still cannot see the images. And this is with the shield off.
Edit: Well the images do show when I zoom to 25%. But once I hit, I believe 50% is when I run into issues again.
The swag store is not high on the list of priorities because it's not set to do anything more than break even. If I get a chance to work on that then I will but it's easier for me to just remove the links.
