I tested DNS availability a bit with my Pi-Hole, using all assigned IPs. I run it with unbound
as upstream DNS on localhost
. There's something about the server hostname now showing at 1.
I can see Server: UnKnown
at 1.
I can see defined server names at 2. and 3.
The hostnames are defined as follows:
fe80::
local IPv6 address + hostnamerpi-dnshole.fritz.box
in/etc/hosts
. Server hostname is reported incorrectly. -
10.1.1.6
IPv4 address + hostnamerpi-dnshole.fritz.box
in/etc/hosts
. Server hostname is reported correctly. -
2a00::
IPv6 and hostnamerpi-dnshole
defined in some config file by runningpi-hole -r
Should it show UnKnown
at 1.? If not, how can I make it report the hostname for the link lokal IPv6, as it does with the other assigned IPs?
