Pi-hole's default cache directive conflicts with cache-size directive in SoftAP0
I know this is a late response, but I was having the same issue today. When Pi-Hole is installed, it's files contain a cache-size directive. This conflicts with the cache-size directive in SoftAP0 that gets generated at boot time
I wanted to keep the functionality of providing DNS for the USB connections, so I updated the script /opt/scripts/boot/am335x_evm.sh by commenting out the following line:
# echo "cache-size=2048" >> ${wfile}
I think this is a similar--if not the same--issue
https://github.com/pi-hole/pi-hole/issues/1521
You are correct. Saved me from entering another issue. I will put a link in that thread to the workaround above. Might help more people that way.
