Container launches, I can access the admin page and it showed queries begin blocked. Within 5 minutes, the web access stops working..."Unable to connect, Firefox can't establish a connection at x.x.x.x
If I stop, then restart the container the admin page becomes accessible again for only a few minutes.
Any suggestions on what may cause this?
Debug token: https://tricorder.pi-hole.net/n8kg3QhK/
How did you start the container? Did you use a docker run
command? A compose file?
Please, post your compose file or command used to start the container.
I use docker on a Synology so I click the toggle to start the container. I don't know what a compose file is. I don't type any commands.
Your debug log shows your Pi-hole is aware of two network interfaces, both of which are operational for DNS:
[✓] www.propergrass.com is 0.0.0.0 on eth0 (192.168.1.198)
[✓] www.propergrass.com is 0.0.0.0 on eth1 (192.168.10.2)
However, your DHCP server is dishing out three IPv4 addresses as DNS servers:
* Received 322 bytes from eth0:192.168.1.1
Offered IP address: 192.168.1.181
DHCP options:
Message type: DHCPOFFER (2)
router: 192.168.1.1
dns-server: 192.168.1.30
dns-server: 1.1.1.1
dns-server: 8.8.8.8
Two of those IPs belong to public DNS resolvers, allowing clients to by-pass Pi-hole at their discretion. And what device is listening on 192.168.1.30
Pi-hole has to be the sole DNS server for your network.
Currently, none of those DNS server addresses matches any of your Pi-hole host's IPs.
Thank you for pointing this out. I have updated the 192.x.x.30 to the address assigned to the pi-hole container 192.x.x.198.
If I remove the two public DNS servers and my container doesn't work then my whole network loses connectivity. I thought the public servers were used as backup in the event the primary goes down.
Even with the DNS pointing to the container, I am able to start it, then access the admin panel for no more than 1 minute. After 1 minute the server returns an "unreachable" error until I stop then restart it again (via the docker GUI).
