Can't figure this out been trying to get this to work for hours. Keep getting this error. Any help is appreciated!
pihole-FTL: no process found
Stopping pihole-FTL
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service _postFTL: stopping
s6-rc: info: service _postFTL successfully stopped
s6-rc: info: service lighttpd: stopping
Stopping lighttpd
s6-rc: info: service lighttpd successfully stopped
s6-rc: info: service pihole-FTL: stopping
s6-rc: info: service pihole-FTL successfully stopped
s6-rc: info: service _startup: stopping
s6-rc: info: service _startup successfully stopped
s6-rc: info: service _uid-gid-changer: stopping
s6-rc: info: service _uid-gid-changer successfully stopped
s6-rc: info: service cron: stopping
Stopping cron
s6-rc: info: service cron successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service cron: starting
s6-rc: info: service cron successfully started
s6-rc: info: service _uid-gid-changer: starting
s6-rc: info: service _uid-gid-changer successfully started
s6-rc: info: service _startup: starting
ServerIP is deprecated. Converting to FTLCONF_LOCAL_IPV4
[i] Starting docker specific checks & setup for docker pihole/pihole
[i] Setting capabilities on pihole-FTL where possible
[i] Applying the following caps to pihole-FTL:
CAP_CHOWN
CAP_NET_BIND_SERVICE
CAP_NET_RAW
Failed to set capabilities on file `/usr/bin/pihole-FTL' (Operation not supported)
The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
[!] ERROR: Unable to set capabilities for pihole-FTL. Cannot run as non-root.
If you are seeing this error, please set the environment variable 'DNSMASQ_USER' to the value 'root'
s6-rc: info: service _startup successfully started
s6-rc: info: service pihole-FTL: starting
s6-rc: info: service pihole-FTL successfully started
s6-rc: info: service lighttpd: starting
s6-rc: info: service lighttpd successfully started
s6-rc: info: service _postFTL: starting
s6-rc: info: service _postFTL successfully started
s6-rc: info: service legacy-services: starting
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
s6-rc: info: service legacy-services successfully started
Installation Failure: /etc/pihole/setupVars.conf does not exist!
Please run 'pihole -r', and choose the 'reconfigure' option to fix.
Stopping pihole-FTL
Stopping pihole-FTL
Stopping pihole-FTL
