Mad
March 9, 2021, 5:41pm
1
Hi!
Maybe I am completely wrong here, but I thought you may have an idea what's going on.
After pi-hole/unbound has been running without any problems for about two years now, it suddenly started not resolving one subdomain: weatherstation.wunderground.com. wunderground.com itself is resolved fine, the subdomain however produces "temporary error in name resolution" or sometimes a timeout.
A dig response:
dig weatherstation.wunderground.com
; <<>> DiG 9.11.5-P4-5.1+deb10u3-Raspbian <<>> weatherstation.wunderground.com
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 18541
;weatherstation.wunderground.com. IN A
;; Query time: 5 msec
;; WHEN: Di Mär 09 18:24:13 CET 2021
;; MSG SIZE rcvd: 60
I do have a level 4 debug log if anyone is interested, the important part may be:
[1615309613] unbound[28569:0] info: iterator operate: query weatherstation.wunderground.com. A IN
[1615309613] unbound[28569:0] debug: process_response: new external response event
[1615309613] unbound[28569:0] info: scrub for com. NS IN
[1615309613] unbound[28569:0] info: response for weatherstation.wunderground.com. A IN
[1615309613] unbound[28569:0] info: reply from <com.> 192.55.83.30#53
[1615309613] unbound[28569:0] info: incoming scrubbed packet: ;; ->>HEADER<<- opcode: QUERY, rcode: NOERROR, id: 0
;; flags: qr ; QUERY: 1, ANSWER: 0, AUTHORITY: 10, ADDITIONAL: 0
;; AUTHORITY SECTION:
wunderground.com. 86400 IN NS a11-66.akam.net.
wunderground.com. 86400 IN NS a10-65.akam.net.
wunderground.com. 86400 IN NS a1-70.akam.net.
wunderground.com. 86400 IN NS a14-64.akam.net.
wunderground.com. 86400 IN NS a13-67.akam.net.
wunderground.com. 86400 IN NS a24-65.akam.net.
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN NSEC3 1 1 0 - ck0q1gin43n1arrc9osm6qpqr81h5m9a NS SOA RRSIG DNSKEY NSEC3PARAM ;{flags: optout}
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN RRSIG NSEC3 8 2 86400 20210313054023 20210306043023 58540 com. ML/ush0Hvdw0xdTHUz8cgFeLWqTp9Zy/4OXQp9G2kIXMqHE/R9acR2lNhjS5euFMkSeKSt1FxOGtUriOEaHn9Pgpn6woncHl2iTBEyFVBhPnolnJPX3NiFOjIZs2$
D2LSED27795ECVMN8KSI2M1EFJHDJDF7.com. 86400 IN NSEC3 1 1 0 - d2lt6a84mh8acvird6t0mn7ofg1l9h0f NS DS RRSIG ;{flags: optout}
D2LSED27795ECVMN8KSI2M1EFJHDJDF7.com. 86400 IN RRSIG NSEC3 8 2 86400 20210315045746 20210308044746 58540 com. PRfEfj4G/FoSrGo/bjTzzFeCiMKe6m7pLW5NMNrdkGVAZxBtugXs/F/BhO+qYI/FGtqGrEIuE3FrhvvwAVkC1Ct8SV8P6SJEG/BMjuVwhLv6iPCprgSESmy6kAJY$
;; ADDITIONAL SECTION:
;; MSG SIZE rcvd: 716
[1615309613] unbound[28569:0] debug: iter_handle processing q with state QUERY RESPONSE STATE
[1615309613] unbound[28569:0] info: query response was REFERRAL
[1615309613] unbound[28569:0] info: negcache insert referral com. NS IN
[1615309613] unbound[28569:0] info: negcache rr CK0POJMG874LJREF7EFN8430QVIT8BSM.com. NSEC3 IN
[1615309613] unbound[28569:0] info: negcache rr D2LSED27795ECVMN8KSI2M1EFJHDJDF7.com. NSEC3 IN
[1615309613] unbound[28569:0] info: DelegationPoint<wunderground.com.>: 6 names (6 missing), 0 addrs (0 result, 0 avail) parentNS
[1615309613] unbound[28569:0] info: a24-65.akam.net.
[1615309613] unbound[28569:0] info: a13-67.akam.net.
[1615309613] unbound[28569:0] info: a14-64.akam.net.
[1615309613] unbound[28569:0] info: a1-70.akam.net.
[1615309613] unbound[28569:0] info: a10-65.akam.net.
[1615309613] unbound[28569:0] info: a11-66.akam.net.
[1615309613] unbound[28569:0] debug: cleared outbound list for next round
[1615309613] unbound[28569:0] debug: iter_handle processing q with state QUERY TARGETS STATE
[1615309613] unbound[28569:0] info: processQueryTargets: weatherstation.wunderground.com. A IN
[1615309613] unbound[28569:0] debug: processQueryTargets: targetqueries 0, currentqueries 0 sentcount 0
[1615309613] unbound[28569:0] debug: attempt to get extra 3 targets
[1615309613] unbound[28569:0] info: new target a14-64.akam.net. A IN
[1615309613] unbound[28569:0] info: new target a1-70.akam.net. A IN
[1615309613] unbound[28569:0] info: new target a10-65.akam.net. A IN
[1615309613] unbound[28569:0] debug: no current targets -- waiting for 3 targets to resolve.
The interesting thing: google dns resolves the subdomain just fine to 169.63.130.179
Would be glad if anyone had any hints how to progress further on this matter.
Thanks! Mathew
Check the DNSSEC for that domain, it's not following the RFCs.
Mad
March 9, 2021, 6:14pm
3
Thank you for your lightning fast response!
So in this case, probably nothing I can do
But is the SHA-1 signing error not only relevant for the cloud domain and not for the .com part? Sorry just curious this is not really my area of expertise...
Is there a quickfix I might try?
First, lets make sure it really is DNSSEC that is causing the failure. The dig response shows SERVFAIL, but that's pointing to 127.0.0.1 Port 53.
What port is unbound running on?
Does dig show SERVFAIL if you directly query unbound?
What does the Pi-hole admin interface show for the queries?
Does it still fail with DNSSEC disabled on `unbound?
Mad
March 9, 2021, 7:22pm
5
Yes, it still fails when DNSSEC is disabled
Unbound runs on 5353, Pi-hole runs on 53 and uses 127.0.0.1:5353 as upstream DNS
Yes, SERVFAIL also occurs when directly querying unbound
Queries to unbound:
Query wunderground.com
pi@rasp:~ $ dig wunderground.com @127.0.0.1 -p 5353
; <<>> DiG 9.11.5-P4-5.1+deb10u3-Raspbian <<>> wunderground.com @127.0.0.1 -p 5353
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 33418
;wunderground.com. IN A
wunderground.com. 3600 IN A 92.122.254.27
;; Query time: 25 msec
;; SERVER: 127.0.0.1#5353(127.0.0.1)
;; WHEN: Di Mär 09 20:17:29 CET 2021
;; MSG SIZE rcvd: 61
Query weatherstation.wunderground.com to unbound
pi@rasp:~ $ dig weatherstation.wunderground.com @127.0.0.1 -p 5353
; <<>> DiG 9.11.5-P4-5.1+deb10u3-Raspbian <<>> weatherstation.wunderground.com @127.0.0.1 -p 5353
Query weatherstation.wunderground.com to google
pi@rasp:~ $ dig weatherstation.wunderground.com @8.8.8.8
; <<>> DiG 9.11.5-P4-5.1+deb10u3-Raspbian <<>> weatherstation.wunderground.com @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 18297
;; flags: qr rd ra; QUERY: 1, ANSWER: 9, AUTHORITY: 0, ADDITIONAL: 1
weatherstation.wunderground.com. 52 IN CNAME rtupdate.wunderground.com.
rtupdate.wunderground.com. 3 IN CNAME prod-pws-ng-ingest.pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud.
prod-pws-ng-ingest.pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 271 IN CNAME pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud.
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.55.126.244
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.61.113.60
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.63.130.180
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.63.130.179
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.55.126.243
pws-ng-prod-iks-wdc-01-997b58a668d15d562a6bed58ea7c5f9e-0001.us-east.containers.appdomain.cloud. 1 IN A 169.61.113.58
;; Query time: 39 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Di Mär 09 20:18:08 CET 2021
;; MSG SIZE rcvd: 321
Pi-hole shows:
2021-03-09 20:08:15 A weatherstation.wunderground.com localhost OK (forwarded) SERVFAIL
What is your unbound.conf file contents?
Mad
March 9, 2021, 7:30pm
7
server:
logfile: "/var/log/unbound/unbound.log"
verbosity: 0
port: 5353
do-ip4: yes
do-udp: yes
do-tcp: yes
do-ip6: no
# root-hints: "/var/lib/unbound/root.hints"
# Trust glue only if it is within the servers authority
harden-glue: yes
harden-dnssec-stripped: yes
use-caps-for-id: no
# Suggested by the unbound man page to reduce fragmentation reassembly problems
edns-buffer-size: 1472
# TTL bounds for cache
cache-min-ttl: 3600
cache-max-ttl: 86400
prefetch: yes
# One thread should be sufficient, can be increased on beefy machines
num-threads: 1
# Ensure kernel buffer is large enough to not loose messages in traffic spikes
so-rcvbuf: 1m
private-address: 192.168.1.0/16
private-address: 10.0.0.0/8
private-address: 10.8.0.0/8
private-address: fd00::/8
private-address: fe80::/10
Why are you modifying the TTL records?
Mad
March 9, 2021, 7:46pm
9
I am? Ah, I am! Admittedly, this part is copy&paste....
Did you follow a guide to set up unbound? Are there other files in unbound.conf.d that make other changes?
Mad
March 9, 2021, 7:48pm
11
I followed this guide - 2 years ago that is: unbound - Pi-hole documentation
Edit: Other files: pi-hole.conf (the unbound.conf) qname-minimisation.conf (yes) and root-auto-trust-anchor-file.conf
Mad:
It's possible that you have something blocking those nameservers and that's causing the timeout. unbound is waiting for a response from those servers and nothing is coming back.
The problem definitely is in unbound and it doesn't look like it's DNSSEC. It's just a complete failure to resolve records.
Mad:
That may be preventing the akamai DNS servers from sending a response. Try it without that enabled and see what happens.
Mad
March 9, 2021, 7:54pm
14
set to no, restarted service, no luck
as for blocking: I wouldn't know what, Pi-hole is the only blocking thing around. Don't know if that counts, but ping is working for those servers...
Can you run dig weatherstation.wunderground.com @a1-70.akam.net
Mad
March 9, 2021, 9:55pm
16
Sure
; <<>> DiG 9.11.5-P4-5.1+deb10u3-Raspbian <<>> weatherstation.wunderground.com @a1-70.akam.net
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32228
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
weatherstation.wunderground.com. 60 IN CNAME rtupdate.wunderground.com.
;; Query time: 26 msec
;; SERVER: 193.108.91.70#53(193.108.91.70)
;; WHEN: Di Mär 09 22:51:46 CET 2021
;; MSG SIZE rcvd: 83
Have you removed the TTL lines from your unbound configuration?
Mad
March 9, 2021, 10:06pm
18
Yes, but it did not change anything
I don't know what else to check.
You're not getting a SERVFAIL from unbound, you're not getting any response at all:
Mad
March 10, 2021, 5:34am
20
Actually that varies. Sometimes I get. Servfail, sometimes I get nothing.
Do you (or anyone else) have a working unbound 1.9 where we could check whether it’s a general unbound problem or if it’s something only I see?
Thank you for all your help do far!
