Pi-hole with UDM Pro
I followed the instructions on Ubiquiti USG - Pi-hole documentation with my UDM Pro.
I used Method 1 with IPv4. The Devices are getting the IP address from the pi hole but the APs and Switches appear offline. They are not offline, they work fine.
Using method 2 everything works fine but then ofcours I won't get reporting by client.
UniFi-OS 3.2.12
Network 8.0.28
Setting UDM Pro as Upstream DNS Server solves the problem.
