Pi-Hole with Ubuntu and UFW
I have noticed sites loading slowly as it looks like the timeout for blocked content takes around 30 seconds. I am aware of using iptables to sort this out.
I did get this working on Ubuntu using iptables somehow however on reboot stopped working and am unable to get it working again by re-entering the rules. Since Ubuntu is using UFW and not iptables I was wondering if anyone has a decent step by step guide for setting up these rules correctly with UFW. I have had a look around and tried a few things but no luck.
I used the following rules
iptables -A INPUT -p tcp --destination-port 443 -j REJECT --reject-with tcp-reset
iptables -A INPUT -p udp --destination-port 80 -j REJECT --reject-with icmp-port-unreachable
iptables -A INPUT -p udp --destination-port 443 -j REJECT --reject-with icmp-port-unreachable
ip6tables -A INPUT -p tcp --destination-port 443 -j REJECT --reject-with tcp-reset
ip6tables -A INPUT -p udp --destination-port 80 -j REJECT --reject-with icmp6-port-unreachable
ip6tables -A INPUT -p udp --destination-port 443 -j REJECT --reject-with icmp6-port-unreachable
Thanks for your assistance
I have figured out the issue. But is not what I excpected. Since the ip address of my pi-hole server changed the pi-hole needed re configuring. So I ran pihole -r and that resolved the issue.
Also I am not 100% but I added this to the /etc/ufw/after.rules and it seemed to work.
# Pi-Hole
-A ufw-after-input -p tcp --destination-port 443 -j REJECT --reject-with tcp-reset
-A ufw-after-input -p udp --destination-port 80 -j REJECT --reject-with icmp-port-unreachable
-A ufw-after-input -p udp --destination-port 443 -j REJECT --reject-with icmp-port-unreachable
and /etc/ufw/after6.rules
# Pi-Hole
-A ufw6-after-input -p tcp --destination-port 443 -j REJECT --reject-with tcp-reset
-A ufw6-after-input -p udp --destination-port 80 -j REJECT --reject-with icmp6-port-unreachable
-A ufw6-after-input -p udp --destination-port 443 -j REJECT --reject-with icmp6-port-unreachable
I hope that helps
