Pi-Hole with Stubby - FTL not loading
hi community.
I have stubby installed, unfortunately I have since then no FTL connection more. have the system completely reinstalled and as soon as I install stubby he loses the FTL connection. Can anyone explain to me? maybe something stuck with PiVPN? About help, I'm grateful :slight_smile:
This sounds like a stubby configuration problem. Please upload a debug log and paste the token here and we can look at the Pi-Hole side of the setup.
the funny thing is that I can not update raspi via sudo apt-get update anymore.
thanks for the help =)
This appears to be because your DNS resolution is not working on the Pi. From your debug log it appears stubby is on port 53, which is the port pihole-FTL needs.
127.0.1.1:53 stubby (IPv4)
[::1]:53 stubby (IPv6)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
[✗] Failed to resolve ads.pointroll.com.29591.9190.302br.net via localhost (127.0.0.1)
[✗] Failed to resolve ads.pointroll.com.29591.9190.302br.net via Pi-hole (192.168.178.7)
[✓] doubleclick.com is 172.217.168.14 via a remote, public DNS server (8.8.8.8)
thanks, I must open in the iptables port?
No, I think you need to get stubby installed so it listens on a port other than 53.
Did your Pi-Hole work properly before you installed stubby?
the PI hole worked perfectly before, only when I stubby installed comes the ftl is offline.
Unfortunately, do not continue :frowning:
Your solution would be to uninstall stubby, then install stubby correctly.
Another encrypted DNS option is DNS over HTTPS.
Thank you, I will rebuild the system and try unbound. would not know what I did wrong with stubby.
