Hi!
If you want https active on Lighttpd with Pi-Hole: (only IPv4)
Here's a custom config of:
"/etc/lighttpd/lighttpd.conf"
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
)server.document-root = "/var/www/html"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.use-ipv6 = "disable"
accesslog.format = "%{%s}t|%V|%r|%s|%b"index-file.names = ( "index.php", "index.html", "index.lighttpd.html" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )mimetype.assign = ( ".png" => "image/png",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".html" => "text/html",
".js" => "application/javascript",
".json" => "application/json",
".txt" => "text/plain",
".svg" => "image/svg+xml" )include_shell "find /etc/lighttpd/conf-enabled -name '
*.conf' -a ! -name 'letsencrypt.conf' -printf 'include "%p"\n' 2>/dev/null"$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
)$HTTP["url"] =~ ".ttf$" { setenv.add-response-header = ( "Access-Control-Allow-Origin" => "`*`" ) }}
$HTTP["url"] =~ "^/admin/.(
url.access-deny = ("")
}include_shell "cat external.conf 2>/dev/null"
server.modules += ( "mod_openssl" )
$SERVER["socket"] == "pi-hole-ip-here:443" {
protocol = "https://"ssl.engine = "enable"
ssl.disable-client-renegotiation = "enable"
ssl.pemfile = "/path-to/your-.pem-file-here"
ssl.ca-file = "/path-to/your-.pem-file-here"ssl.dh-file = "/path-to/your-Diffie–Hellman-key.pem-here"
setenv.add-environment = ( "HTTPS" => "on" )
ssl.openssl.ssl-conf-cmd = ( "Protocol" => "ALL, -SSLv2, -SSLv3, -TLSv1, -TLSv1.1", "Curves" => "X25519:prime256v1:secp384r1" )
ssl.cipher-list = "ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK"
ssl.honor-cipher-order = "enable"
setenv.add-response-header = ( "Strict-Transport-Security" => "max-age=63072000; includeSubDomains; preload", "X-Frame-Options" => "DENY", "X-Content-Type-Options" => "nosniff" )
}$HTTP["scheme"] == "http" {
$HTTP["host"] =~ ".*" {
url.redirect = ( ".*" => "https://%0$0" )
}server.modules += ( "mod_fastcgi" )
fastcgi.server = ( ".php" =>
"bin-path" => "/usr/bin/php-cgi","socket" => "path-to-your-php-fast-cgi-socket/file-name.socket" + var.PID, "max-procs" => 1, "bin-environment" => ( "PHP_FCGI_CHILDREN" => "4", "PHP_FCGI_MAX_REQUESTS" => "10000" ), "bin-copy-environment" => ( "PATH", "SHELL", "USER" ), "check-local" => "enable", "broken-scriptfilename" => "enable"))
Before edit settings at your owns, create your OpenSSL keys.
Edit:
$SERVER["socket"] == "pi-hole-ip-here:443" # from your: "/etc/pihole/setupVars.conf" (IPV4_ADDRESS=)
ssl.ca-file = "/path-to/your-.pem-file-here"ssl.dh-file = "/path-to/your-Diffie–Hellman-key.pem-file-here"
"socket" => "/path-to/your-php-fast-cgi-socket.socket-file-here" + var.PID,
Possibly adapt the iptables:
/sbin/iptables -A INPUT -p udp --dport 80 -j REJECT --reject-with icmp-port-unreachable
/sbin/iptables -A INPUT -p tcp --dport 443 -j REJECT --reject-with tcp-reset
/sbin/iptables -A INPUT -p udp --dport 443 -j REJECT --reject-with icmp-port-unreachable
/sbin/iptables -A INPUT -p tcp --dport 4711 -j ACCEPT/sbin/iptables -A OUTPUT -p tcp --dport 80 -j ACCEPT
/sbin/iptables -A OUTPUT -p tcp --dport 443 -j ACCEPT
I removed at "/etc/lighttpd/conf-enabled" these 2 files:
10-fastcgi.conf
15-fastcgi-php.conf
because "fast-cgi" is in my lighttpd.conf.
At your own risk!
