Pi-hole will it work with Kali Linux?
The issue I am facing:
Fresh install on Kali Linux. Does anyone knows if works already?
Details about my system:
Kali 2023.3
Linux kali 6.5.0-kali3-arm64 #1 SMP Debian 6.5.6-1kali1 (2023-10-09) aarch64 GNU/Linux
(Nothing) Will it be available one day for "Kali Linux"?
Give it a go, see what happens and report back!
IT WONT WORK WITH KALI LINUX. I already test it. :sleepy:
HOW DO YOU KNOW, WHAT DIDN'T WORK?
Already, Kali Linux is not supported.
So we can start from there.
If you don't believe, install it and install pi-hole and let us know...
You can install Pi-hole on unsupported OSes, if you know how to read.
I don't really have a desire to install Kali, but thanks.
If you tried to install Pi-hole and saw a message saying your OS is unsupported you can still try to install it using this command:
curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
It didn't work
