Pi-Hole Web interface: 503 Service Unavailable
Cannot open web interface, the strange is this raspberry pi is only hosting pihole.
running on Raspberry Pi 3 Model B Rev 1.2
Debian 11 bullseye 64
giving a look to debug, seems cannot detect php version.
php -v give segmentation fault, so maybe something broke with php
restart doesn't help.
pihole -r doesnt' help.
thx in advance.
https://tricorder.pi-hole.net/UBKy3NSJ/
Your debug log shows there is no PHP installed on the device:
[✗] php version could not be detected.
There is also another error:
[i] Distro: Debian
[i] Version: 11
[✗] dig return code: 139
[✗] dig response: 139
[✗] Error: dig command failed - Unable to check OS
This is very similar to this post: Pihole -up error: Retrieval of supported OS list failed. dig failed with return code 139. Unable to determine if the detected OS (Raspbian 10) is supported - #8 by jfb
the strange thing is that it's not an installation done now, I mean until a few days ago, or a few weeks ago it was fully functional, and sure I didn't remove php.
Ya Dig is in segmentation fault too, just ckecked it :frowning:
I'm not saying this is the case, but sometimes this means your SD card is failing and some files were lost.
so could it be a fault sd, all so strange, so I will get a new sd and reinstall from scratch. Ty
