My network comprises of a Virgin Media Hub 3 which acts as a modem and passes the Wi Fi signel through to Archer A7 router via an ethernet cable.
The question I have is:
In the network I have is it possible to set the Pi-hole up with an ethernet cable connection to the Virgin router and then just disable the DHPC on the Archer A7.
Any help on this would be much appreciated.
Cheers,
John
