Hello, Is there a way to use Pi-hole V6 over http instead of https ?
Thank you
Thank you
Did you try using http://pi.hole/admin ?
Is there an error message or something wrong?
Hello, going to http://pi.hole/admin/ returns a 403 Forbidden message.
Debug token is: http://tricorder.pi-hole.net/UpzMdKLx/
The issue is you have lighttpd running on port 80 (probably a leftover from a previous Pi-hole v5 install).
If you need to keep lighttpd, you have 2 options:
lighttpd port (to something different than 80) orIf you are not using lighttpd, you can safely disabled it (or even uninstall it) and restart pihole-FTL.
EDIT:
I just noticed you are already using port 8080 for pihole-FTL (I think this is automatically set when port 80 is in use):
port = "8080,[::]:8080,443s,[::]:443s" ### CHANGED, default = "80,[::]:80,443s,[::]:443s"
You can access the web interface using using http://pi.hole:8080/admin.
If you want to use port 80, you will need to disable lighttpd and change /etc/pihole/pihole.toml to use port 80.
Thank you I will give the disable/uninstall a try. Is there an easy way/instructions on how to do that ?
Thanks
This command will uninstall lighttpd:
sudo apt remove lighttpd
Thank you.
That’s awesome, thank you.
sudo systemctl disable --now lighttpd.service
All I needed to do was disable as shown above.
I wasn't using port 8080, as confirmed with:
sudo pihole-FTL --config webserver.port
Web interface now doesn't bug me for https certs.
