Pi-Hole (v6) intermittent DNS failure
Pi-Hole should resolve sites without stalling or buffering. Happens on Windows10 & 11, Android
Several times a day name resolution stops and l cannot connect to any site - returns to normal after a few minutes.
Debug Token
Debug Token - 17032025@09:50
System is a 8GB Rpi5with a 500GGB nVMe drive, Latest OS and latest PiHole with Unbound
Router is a Fritz!Box 7530 on latest firmware.
If l bypass the PiHole for DNS and switch to public or my ISPs DNS servers everything works OK. This problem only started after 'upgrading' to v6 - this system is a fresh install of everything
Only error is a maximum number of DNS queries reached
That error isn't present in your current debug log.
If that occurs again, let's see how many DNS requests Pi-hole had to handle in the minute before, and whether that would be related to certain domains or clients:
sudo pihole-FTL sqlite3 /etc/pihole/pihole-FTL.db "SELECT count(*) FROM queries \
WHERE timestamp > strftime('%s','2025-03-18 15:00:00.142', '-60 seconds', 'utc') \
AND timestamp <= strftime('%s','2025-03-18 15:00:00.142', 'utc');"
sudo pihole-FTL sqlite3 /etc/pihole/pihole-FTL.db "SELECT domain, count(*) FROM queries \
AND timestamp <= strftime('%s','2025-03-18 15:00:00.142', 'utc') \
GROUP BY domain ORDER BY 2 DESC LIMIT 10;"
sudo pihole-FTL sqlite3 /etc/pihole/pihole-FTL.db "SELECT client, count(*) FROM queries \
GROUP BY client ORDER BY 2 DESC LIMIT 10;"
Substitute 2025-03-18 15:00:00.142 with the timestamp as logged in Pi-hole's error message.
Maximum concurrent warnings are often caused by a DNS loop of sorts, or by upstream DNS server unresponsiveness, less often by a misbehaving client issuing DNS queries excessively.
It seems there are at least three router type devices in your network, as your debug log shows three different RAs, originating from your Fritzbox, a Draytek and an unknown device.
Does anyone of those use your Pi-hole for DNS server?
Also, your debug log shows that your Fritzbox is advertising its own IPv6 addresses as local DNS servers:
-rw-r--r-- 1 root root 151 Mar 16 06:52 /etc/resolv.conf
   nameserver 192.168.104.39
   nameserver fd<redacted>89
   nameserver 2a<redacted>89
Fritzbox routers can be configured to not advertise any IPv6 DNS servers at all, see Unresolved ipv6 adress in my top list - #4 by Bucking_Horn.
Thanks for the reply.
The other routers are used to provide Wifi in various rooms of the house. They are configured as WiFi access points; no DHCP, no routing. Exception is the Draytek that is also the DHCP server for my home network; my intention is to move DHCP to the Pi-Hole or the Fritz!Box at some point.
I've disabled IP6 on the Fritz!Box
I tried to upload a log file while the problem was happening but as it (my Pi-Hole server) couldn't resolve any names the upload failed so no Debug Token issued.
Chris
