Hallo zusammen.
Beim Update der FTL kommt folgender Fehler:
(Datei ist aber über wget erreichbar)
pihole -up
[i] Existing PHP installation detected : PHP version 7.3.31-1~deb10u5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for dialog
[✓] Checking for ca-certificates
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for dnsutils
[✓] Supported OS detected
[i] Checking for / installing Required dependencies for this install script...
[i] Performing unattended setup, no dialogs will be displayed
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Checking for / installing Required dependencies for Pi-hole software...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for iputils-ping
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for idn2
[✓] Checking for libcap2-bin
[✓] Checking for netcat-openbsd
[✓] Checking for procps
[✓] Checking for jq
[✓] Checking for lighttpd
[✓] Checking for php7.3-common
[✓] Checking for php7.3-cgi
[✓] Checking for php7.3-sqlite3
[✓] Checking for php7.3-xml
[✓] Checking for php7.3-intl
[✓] Checking for php7.3-json
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARMv7 processor (with hard-float support)
[i] Downloading and Installing FTL...curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-armv7-linux-gnueabihf not found
[✗] FTL Engine not installed
Server ist up to Date.
Danke für die Hilfe!
[Bitte beschreibe, welches Verhalten du beobachtet hast und was du eigentlich erwarten würdest. Bitte sei so präzise wie möglich. Nenne wichtige Details, z.B. verwendete Hardware und Betriebssystem]
