Pi-Hole Switched IP while on
not to switch ip while its on.
it switched to a new ip address from its manually static ip
http://oi66.tinypic.com/28bdwlx.jpg
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-07-09:18:40:44 debug log has been initialized.
[i] Core: v3.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3.1-0-gfbee18e
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.75
[i] 1.4.35
[i] 7.0.30
[✓] Ubuntu 16.04.4 LTS
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✓] IPv4 address(es) bound to the enp0s3 interface:
   192.168.1.135/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✓] IPv6 address(es) bound to the enp0s3 interface:
   fe80::2a0:98ff:fe49:99f3 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   * Pinging 192.168.1.1...
[✓] Gateway responded.
[] is in use by
[22] is in use by sshd
[53] is in use by dnsmasq
[80] is in use by lighttpd
[✓] chaseonlinebanking1.world is 192.168.1.101 via localhost (127.0.0.1)
[✗] Failed to resolve chaseonlinebanking1.world via Pi-hole (192.168.1.101)
[✓] doubleclick.com is 172.217.5.78 via a remote, public DNS server (8.8.8.8)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
    PIHOLE_INTERFACE=enp0s3
    IPV4_ADDRESS=192.168.1.101/24
    IPV6_ADDRESS=
    PIHOLE_DNS_1=72.235.80.12
    PIHOLE_DNS_2=72.235.80.4
    QUERY_LOGGING=true
    INSTALL_WEB=true
    LIGHTTPD_ENABLED=1
    DNSMASQ_LISTENING=single
[✓] X-Pi-hole: A black hole for Internet advertisements.
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 4868979 Jul  8 11:41 /etc/pihole/gravity.list
   192.168.1.101 0.0.0.0
   192.168.1.101 0.r.msn.com
   192.168.1.101 0.start.bz
   192.168.1.101 000.0x1f4b0.com
   192.168.1.101 zzz.clickbank.net
   192.168.1.101 zzzezeroe.fr
   192.168.1.101 zzzpooeaz-france.com
   192.168.1.101 zzzrtrcm2.com
-rw-r--r-- 1 root root 633 Jul  8 11:41 /etc/pihole/adlists.default
-rw-r--r-- 1 root root 633 Jul  8 11:41 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 43 Jul  8 11:41 /etc/pihole/local.list
   192.168.1.101 PiHole
   192.168.1.101 pi.hole
-rw-r--r-- 1 root root 238 Jul  8 11:41 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root syslog
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root syslog
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 1519 Jul  8 12:22 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries=extra
   local-ttl=2
   log-async
   server=72.235.80.12
   server=72.235.80.4
   interface=enp0s3
-rw-r--r-- 1 root root 3027 Jul  8 11:41 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Jul  8 11:41 /etc/cron.d/pihole
   29 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   51 15  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 1270 Jul  9 18:39 /var/log/lighttpd/error.log
   2018-07-08 11:41:13: (log.c.164) server started
   2018-07-08 11:41:22: (server.c.1558) server stopped by UID = 0 PID = 1
   2018-07-08 11:41:22: (log.c.164) server started
   2018-07-08 12:17:26: (mod_fastcgi.c.2695) FastCGI-stderr: PHP Notice:  Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
   2018-07-08 12:19:09: (server.c.1558) server stopped by UID = 0 PID = 1
   2018-07-08 12:19:15: (log.c.164) server started
   2018-07-09 18:28:27: (mod_fastcgi.c.2695) FastCGI-stderr: PHP Notice:  Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
   2018-07-09 18:36:16: (mod_fastcgi.c.2695) FastCGI-stderr: PHP Notice:  Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
   2018-07-09 18:39:50: (server.c.1558) server stopped by UID = 0 PID = 1
   2018-07-09 18:39:56: (log.c.164) server started
-rw-r--r-- 1 pihole pihole 4787 Jul  9 18:39 /var/log/pihole-FTL.log
   [2018-07-09 00:00:02.031] NOTICE: pihole.log has been flushed
   [2018-07-09 00:00:02.031]   Resetting internal data structure
   [2018-07-09 00:00:02.031]   Queries in memory before flushing: 134
   [2018-07-09 00:00:02.032] FATAL: Trying to free NULL pointer in pihole_log_flushed() (flush.c:61)
   [2018-07-09 00:00:02.074] Gravity list entries: 132559
   [2018-07-09 00:00:02.074] No blacklist present
   [2018-07-09 00:00:02.074] No wildcard blocking list present
   [2018-07-09 00:00:02.075] Notice: Increasing queries struct size from 0 to 10000 (440.21 KB)
   [2018-07-09 00:00:02.075] Notice: Increasing domains struct size from 0 to 1000 (472.21 KB)
   [2018-07-09 00:00:02.075] Notice: Increasing clients struct size from 0 to 10 (472.45 KB)
   [2018-07-09 00:00:02.075] New client: 127.0.0.1 localhost (0/10)
   [2018-07-09 00:00:02.075] Notice: Increasing forwarded struct size from 0 to 4 (472.60 KB)
   [2018-07-09 00:00:02.079] New forward server: 72.235.80.4 hnlldnsdhcp.hawaiiantel.net (0/4)
   [2018-07-09 00:00:02.079] Notice: Increasing overTime struct size from 0 to 100 (478.24 KB)
   [2018-07-09 00:00:02.083] New forward server: 72.235.80.12 wphudnsdhcp.hawaiiantel.net (1/4)
   [2018-07-09 00:00:02.083] Imported 132 queries from the long-term database
   [2018-07-09 00:00:02.083] Reading from /var/log/pihole.log (rw-r--r--)
   [2018-07-09 05:30:18.876] Notice: Increasing overTime struct size from 100 to 200 (484.95 KB)
   [2018-07-09 18:39:56.697]
   [2018-07-09 18:39:56.697] FTL branch: v3.0
   [2018-07-09 18:39:56.697] FTL version: v3.0
   [2018-07-09 18:39:56.697] FTL commit: a1b2fa03f8f3e3713b57a26a4e9a062fec0573d7
   [2018-07-09 18:39:56.697] FTL date: 2018-02-14 12:45:47 -0800
   [2018-07-09 18:39:56.697] FTL user: pihole
   [2018-07-09 18:39:56.697] Notice: Found no readable FTL config file
-rw-r--r-- 1 dnsmasq root 67161 Jul  9 18:41 /var/log/pihole.log
   -----head of pihole.log------
   Jul  9 00:00:02 dnsmasq[1545]: 85 127.0.0.1/54861 query[PTR] 4.80.235.72.in-addr.arpa from 127.0.0.1
   Jul  9 00:00:02 dnsmasq[1545]: 85 127.0.0.1/54861 forwarded 4.80.235.72.in-addr.arpa to 72.235.80.4
   Jul  9 00:00:02 dnsmasq[1545]: 85 127.0.0.1/54861 forwarded 4.80.235.72.in-addr.arpa to 72.235.80.12
   Jul  9 00:00:02 dnsmasq[1545]: 85 127.0.0.1/54861 reply 72.235.80.4 is HNLLDNSDHCP.hawaiiantel.net
   Jul  9 00:00:02 dnsmasq[1545]: 86 127.0.0.1/33597 query[PTR] 12.80.235.72.in-addr.arpa from 127.0.0.1
   Jul  9 00:00:02 dnsmasq[1545]: 86 127.0.0.1/33597 forwarded 12.80.235.72.in-addr.arpa to 72.235.80.12
   Jul  9 00:00:02 dnsmasq[1545]: 86 127.0.0.1/33597 reply 72.235.80.12 is WPHUDNSDHCP.hawaiiantel.net
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 query[A] ntp.ubuntu.com from 127.0.0.1
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 forwarded ntp.ubuntu.com to 72.235.80.4
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 forwarded ntp.ubuntu.com to 72.235.80.12
   Jul  9 01:31:23 dnsmasq[1545]: 88 127.0.0.1/51494 query[AAAA] ntp.ubuntu.com from 127.0.0.1
   Jul  9 01:31:23 dnsmasq[1545]: 88 127.0.0.1/51494 forwarded ntp.ubuntu.com to 72.235.80.12
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 reply ntp.ubuntu.com is 91.189.89.199
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 reply ntp.ubuntu.com is 91.189.91.157
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 reply ntp.ubuntu.com is 91.189.94.4
   Jul  9 01:31:23 dnsmasq[1545]: 87 127.0.0.1/51494 reply ntp.ubuntu.com is 91.189.89.198
   Jul  9 01:31:23 dnsmasq[1545]: 88 127.0.0.1/51494 reply ntp.ubuntu.com is 2001:67c:1560:8003::c8
   Jul  9 01:31:23 dnsmasq[1545]: 88 127.0.0.1/51494 reply ntp.ubuntu.com is 2001:67c:1560:8003::c7
   Jul  9 01:49:08 dnsmasq[1545]: 89 127.0.0.1/60596 query[A] ntp.ubuntu.com from 127.0.0.1
   Jul  9 01:49:08 dnsmasq[1545]: 89 127.0.0.1/60596 forwarded ntp.ubuntu.com to 72.235.80.4
[✓] ** FINISHED DEBUGGING! **
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
    * Using openssl for transmission.
[✓] Your debug token is: 99q1k0ji5c
   * Provide the token above to the Pi-hole team for assistance at
   * https://discourse.pi-hole.net
   * Your log will self-destruct on our server after 48 hours.
   * A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
What is the output from ip -4 address? It sounds like you have it set to DHCP client and that is changing the IP address.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.1.135/24 brd 192.168.1.255 scope global enp0s3
And the output from cat /etc/dhcpcd.conf please?
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
interface enp0s3
  static ip_address=192.168.1.101/24
  static routers=192.168.1.1
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
#clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
duid
# Persist interface configuration when dhcpcd exits.
persistent
sorry that was the top. i missed that
Thanks, finally the contents of /etc/network/interfaces. I think you might have to set the static IP in /etc/network/interfaces and remove the interface line from /etc/dhcpcd.conf but lets look at your /etc/network/interfaces first.
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto enp0s3
iface enp0s3 inet dhcp
Okay, the options are to either set the line to iface enp0s3 inet manual or configure the interface for a static IP address in /etc/network/interfaces and remove the /etc/dhcpcd.conf section setting the static IP. The configuration now is still asking for an IP address from DHCP and overriding dhcpcd.
auto lo
auto enp0s3
/etc/dhcpcd.conf
#controlgroup wheel
hostname
#clientid
# or
duid
persistent
option rapid_commit
option ntp_servers
#slaac private
#interface enp0s3
#  static ip_address=192.168.1.101/24
#  static routers=192.168.1.1
#  static domain_name_servers=127.0.0.1
Like that?
If you set the /etc/network/interfaces to manual you will need to leave in the /etc/dhcpcd.conf configuration untouched.
Only comment out the /etc/dhcpcd.conf lines if you set the /etc/network/interfaces to a static IP configuration as per the Ubuntu documentation for setting a static IP address. networking - How do I set a static IP in Ubuntu? - Ask Ubuntu
