Ads should always be blocked
Ads getting blocked but not always. If i reconnect the devices (Wifi and wired ones) it will work for some time but then stops working again.
8pd9g0ewet
8pd9g0ewet
This is frequently due to another DNS path available to the clients. If given two paths to the internet, they typically with find both. When you re-connect them, they typically use the first DNS they see, which in your case is Pi-Hole. As time goes by, they can find the other DNS path.
Pi-hole is the only DNS i'm using. As far as i know there is also no fallback DNS on the router (Fritzbox) nor repeater. If i take a look at the current network-settings on the devices (Smartphone) the DNS is always the Pi Hole IP.
Till one weak ago, it all worked without problems.
What is the output of this command from the Pi terminal:
echo ">stats" | nc localhost 4711
$ echo ">stats" | nc localhost 4711
domains_being_blocked 135971
dns_queries_today 12381
ads_blocked_today 2641
ads_percentage_today 21.331072
unique_domains 919
queries_forwarded 6952
queries_cached 2788
clients_ever_seen 16
unique_clients 16
dns_queries_all_types 12452
reply_NODATA 119
reply_NXDOMAIN 15
reply_CNAME 395
reply_IP 1090
status enabled
---EOM---
This data indicates that the Pi-Hole is actively blocking domains.
We'll take a look at your debug log.
Thanks for your help!
Disabled ipv6 on the fritzbox?
Yes. - 10 characters
Also the ipv6 part in the fritz internet settings I assume?
Only 1 dhcp server in the lan I assume?
What does ipconfig /all say on a device with ads?
There only one option to activate IPv6 (and it's only for internet settings) and it's disabled.
The Fritzbox one is the only DHCP but most of the clients have a static IP.
I'm on Ubunto so i can give you the output of nmcli dev show enp3s0
When it's working it looks like this:
GENERAL.GERĂ„T: enp3s0
GENERAL.TYP: ethernet
GENERAL.HWADDR: 7C:8B:CA:02:5F:E5
GENERAL.MTU: 1500
GENERAL.STATUS: 100 (verbunden)
GENERAL.VERBINDUNG: Kabelnetzwerkverbindung 1
GENERAL.CON-PFAD: /org/freedesktop/NetworkManager/ActiveConnection/0
WIRED-PROPERTIES.TRĂ„GERFREQUENZ: an
IP4.ADRESSE[1]: 192.168.178.22/24
IP4.GATEWAY: 192.168.178.1
IP4.ROUTE[1]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]: 192.168.178.26
IP4.DOMĂ„NE[1]: fritz.box
IP6.ADRESSE[1]: fd00::1:4dbf:3472:2fda:e86c/64
IP6.ADRESSE[2]: fd00::1:e255:fcb1:978f:3643/64
IP6.ADRESSE[3]: fe80::f5a:eea5:9f9:a885/64
IP6.GATEWAY: fe80::56fa:3eff:fe82:76da
IP6.DNS[1]: fd00::1:56fa:3eff:fe82:76da
IP6.DNS[2]: fe80::56fa:3eff:fe82:76da
If it's not working it looks like this:
GENERAL.MTU: 1500
GENERAL.CON-PFAD: /org/freedesktop/NetworkManager/ActiveConnection/1
The part IP4.ROUTE[1]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
is missing
//Edit: Ok, it's also missing when it's working. Don't know why it showed up the first time.
That is your fritzbox?....Something is sending ipv6 dns and gateway info to your clients.....
Or is this a manual entry?
I think i have found the culprit! The TV-Receiver (Unitymedia Horizon Recorder) got an update a few days ago. Despite everything network related was disabled, it seems that the Receiver somehow startet its own DNS. (You are right, i missed the entry) I've pulled the networkcable and now it looks like that everything went back to normal. I'll report back after some time. Thanks guys!
Yes, do never physicly connect the ziggo horizon with your network.
This piece of hardware is just pure cancer...
