I tested pihole on a vm and got it working - or so I thought - with DNS-Over-HTTPS on Pi-hole.
I then installed pihole DNS-Over-HTTPS on Pi-hole on an old lenovo laptop and removed the pihole vm. It looked like pihole was working from the client as I could see the client ip on the client list on the pihole dashboard.
Since I was going out of town for a week I shut down pihole as well as the client PC. Upon return I booted up pihole the client and even the router. However the client can now not get pihole to do any dns queries although everything works fine from the pihole itself. I can ping 8.8.8.8 for example from the client but I cannot reach google.com.
I tried restarting the systemd services:
sudo systemctl enable cloudflared
sudo systemctl start cloudflared
sudo systemctl status cloudflared
The command dig @127.0.0.1 -p 5053 google.com looks good as well but that is being generated from the pihole which again, works just fine.
Your debug log shows Pi-hole is resolving DNS as expected:
[✓] www.pc-breach-1n6w3h.online is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.pc-breach-1n6w3h.online is 0.0.0.0 via Pi-hole (192.168.46.101)
[✓] doubleclick.com is 216.58.218.238 via a remote, public DNS server (8.8.8.8)
And is working for one other client (which could be localhost):
[2018-10-16 15:52:34.360] Imported 620 queries from the long-term database
[2018-10-16 15:52:34.360] -> Total DNS queries: 620
[2018-10-16 15:52:34.360] -> Cached DNS queries: 101
[2018-10-16 15:52:34.360] -> Forwarded DNS queries: 373
[2018-10-16 15:52:34.360] -> Exactly blocked DNS queries: 146
[2018-10-16 15:52:34.360] -> Unknown DNS queries: 0
[2018-10-16 15:52:34.360] -> Unique domains: 95
[2018-10-16 15:52:34.360] -> Unique clients: 1
[2018-10-16 15:52:34.360] -> Known forward destinations: 1
From a client, run this command to see if the client can connect to the Pi-Hole DNS via the Pi-Hole IP.
dig pi.hole @192.168.46.101 from the client
;; global options +cmd
The strange thing is it worked from the client when I first set it up and only broke after I shut everything down and powered everything back up upon my return from being out of town a week later.
I know it's not the IPs because when I set it up I made sure both the client as well as the pihole had static IPs and that the IPs were reserved in the router.
However what I now realize is that I can simply put an instance of Pi-hole on each client (4) using cloudflared DoH since I run Debian/Ubuntu based Mint as my OS. Kind of overkill but is working on this rather limited resource laptop (2 core 4G RAM) it should be no issue on the bigger rigs (i7s and AMD Bulldozer with 16G RAM)
Not the preferred solution so I will start from scratch one more time but if that does not work then I will go to plan B above.
