I have a Pi-hole setup on a raspberrypi in a docker container.
I noticed today that after i rebooted my raspberrypi my pi-hole stats reset, and keeps happening after each reboot.
In terminal i have been able to run:
docker ps
docker exec -it pihole /bin/bash
pihole -v
result returned =
Pi-hole version is v5.18.3 (Latest: v5.18.3)
web version is v5.21 (Latest: v5.21)
FTL version is v5.25.2 (Latest: v5.25.2)
Searching the internet I see that you can repair docker installations with the command :
'pihole -r'
But docker installations don't seem to support this?
I am somewhat of a novice user, and any help to resolve this is appreciated.
debug token :
[ā] Your debug token is: https://tricorder.pi-hole.net/hKY9bGoS/
Please also post your compose file or docker run command used to start the container.
My docker-compose.yml file :
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
- "80:80/tcp"
environment:
TZ: 'Europe/London'
WEBPASSWORD: 'ThisIsNotMyP@$$w0rd'
volumes:
- './home/piuser/pihole/etc-pihole:/etc/pihole'
- './home/piuser/pihole/etc-dnsmasq.d:/etc/dnsmasq.d'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
restart: unless-stopped
The queries are not stored in the database because your database file is broken.
This file is too small to be a complete database file (it should be at least 80 Kb):
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 28K Oct 30 22:15 /etc/pihole/pihole-FTL.db
Stop the container, go to /home/piuser/pihole/etc-pihole in the host and rename or delete pihole_FTL.db. Then restart the container. A new database should be created.
