I need pi-hole setup in docker but I am having trouble setting up a macvlan
I need the container to have its own IP address as port 53 is in use on the host system
the below setup is not working
sudo docker network create -d macvlan --subnet=10.42.0.0/24 --gateway=10.42.0.1 -o parent=eth0 pub_net
But is this not working because the host is the gateway
and how would I get around that
I use docker compose and this is my network configuration:
networks:
pihole_network:
driver: macvlan
driver_opts:
parent: eth0
ipam:
config:
- subnet: 192.168.10.0/24 # <-- Update
gateway: 192.168.10.252 # <-- Update
ip_range: 192.168.10.201/32 # <-- Update
I think my issue is the fact the host is the gateway
how would I allow host to container connection
I think I got it working using that
the only thing is nothing is being blocked after restoring a backup
