Pi-hole says it's blocking ads but isn't actually
Ads should be blocked on my IOS, android, and desktop systems while my pihole is running.
Even though my raspberry pi is up and running and the interface says it's blocking queries as normal I still see most if not all ads while connected to my WiFi network on all devices. If it is blocking ads, I'm still seeing most of them to the point where I don't notice. I'm using pretty standard blocklists with Unbound. My raspberry pi 4 is connected via Ethernet to my RT-AX68U-5C08 ASUS router. From a glance I don't see anything wrong in the debug log either. Thank you for any help.
https://tricorder.pi-hole.net/qWoSrlGi/
Please provide examples of apps or websites where you are seeing ads.
Note that your DHCP server (the router) is distributing both its own IP and the IP of Pi-hole for DNS. This may lead to DNS bypassing Pi-hole. Given multiple DNS servers available, clients are free to use any of them at any time.
   Timeout: 10 seconds
   * Received 300 bytes from eth0:192.168.50.1
     Offered IP address: 192.168.50.15
     Server IP address: 192.168.50.1
     Relay-agent IP address: N/A
     BOOTP server: (empty)
     BOOTP file: (empty)
     DHCP options:
      Message type: DHCPOFFER (2)
      server-identifier: 192.168.50.1
      lease-time: 86400 ( 1d )
      renewal-time: 43200 ( 12h )
      rebinding-time: 75600 ( 21h )
      netmask: 255.255.255.0
      broadcast: 192.168.50.255
      dns-server: 192.168.50.15
      router: 192.168.50.1
      --- end of options ---
Your debug log runs a test for blocking a domain randomly chosen from your gravity list. Yours shows that Pi-hole is working:
[✓] demo.halimcan.de is 0.0.0.0 on lo (127.0.0.1)
[✓] demo.halimcan.de is 0.0.0.0 on eth0 (192.168.50.15)
[✓] No IPv4 address available on wlan0
[✓] doubleclick.com is 192.178.50.46 via a remote, public DNS server (8.8.8.8)
Your debug log shows the following activity in the past 24 hours. Pi-hole appears to be working normally and resolving DNS queries for network clients.
   [2023-12-03 09:27:15.207 759M] Imported 33342 queries from the long-term database
   [2023-12-03 09:27:15.207 759M]  -> Total DNS queries: 33342
   [2023-12-03 09:27:15.208 759M]  -> Cached DNS queries: 4989
   [2023-12-03 09:27:15.208 759M]  -> Forwarded DNS queries: 12949
   [2023-12-03 09:27:15.208 759M]  -> Blocked DNS queries: 14533
   [2023-12-03 09:27:15.208 759M]  -> Unknown DNS queries: 0
   [2023-12-03 09:27:15.208 759M]  -> Unique domains: 1501
   [2023-12-03 09:27:15.208 759M]  -> Unique clients: 11
   [2023-12-03 09:27:15.208 759M]  -> Known forward destinations: 3
A post was split to a new topic: Pi-hole not blocking ads on some sites
