Your client is not using Pi-hole for DNS, but 192.168.88.1.
Yet your debug log shows that your router is distributing your Pi-hole machine's IPv4 as local DNS server:
* Received 548 bytes from 192.168.88.1 @ wlan0
Offered IP address: 192.168.88.3
DHCP options:
Message type: DHCPOFFER (2)
lease-time: Infinite
router: 192.168.88.1
dns-server: 192.168.88.3
If you changed your router configuration only recently, this may be expected:
DHCP clients would update their DNS information only upon renewing their DHCP lease. You may force clients to do so, e.g. by dis- and reconnecting them to your network, or by power-cycling them.
But it's also unexpected that a direct nslookup for flurry.com through 192.168.88.3 (where your Pi-hole lives) is not blocked.
Let's see how that last lookup registered in Pi-hole.
Run from your Pi-hole machine, what's the result of:
Result of sudo grep flurry.com /var/log/pihole/pihole.log is
May 17 19:17:04 dnsmasq[1360]: query[A] flurry.com from 192.168.88.3
May 17 19:17:04 dnsmasq[1360]: forwarded flurry.com to 1.1.1.1
May 17 19:17:04 dnsmasq[1360]: reply flurry.com is 13.248.158.7
May 17 19:17:04 dnsmasq[1360]: reply flurry.com is 76.223.84.192
May 17 19:17:04 dnsmasq[1360]: query[AAAA] flurry.com from 192.168.88.3
May 17 19:17:04 dnsmasq[1360]: reply flurry.com is NODATA-IPv6
To avoid this restriction, you can post the command output inside a "code block", adding a line with ``` before and after the text, like this:
- Text containing links,
- Text containing @ but you don't want to mention other users,
- command output,
- code or
- any other text you want inside a block
This will be printed like this:
- command output,
- code or
That's unexpected.
Could you provide a fresh debug token, please?
Also, let's take a closer look how Pi-hole handles those unexpectedly forwarded requests.
Please run:
sudo pihole-FTL --config debug.clients true
Afterwards, please share the output of:
sudo pihole-FTL --config dns.blocking.active
nslookup flurry.com 192.168.88.3
In addition, please monitor /var/log/pihole/FTL.log (e.g. via Tools| Tail log files | FTL.log) for DEBUG_CLIENTS lines corresponding to that nslookup, and share the relevant portion.
Not sure the best way to share this or how much you need
DEBUG_CLIENTS lines
2025-05-21 12:56:23.495 DEBUG_CLIENTS Reloading client groups after 529 seconds (1st check)
2025-05-21 12:56:23.495 DEBUG_CLIENTS --> No record for 192.168.88.3 in the client table
2025-05-21 12:56:23.495 DEBUG_CLIENTS Querying gravity database for MAC address of 192.168.88.3...
2025-05-21 12:56:23.495 DEBUG_CLIENTS --> Querying client table for 2c:<redacted>7
2025-05-21 12:56:23.495 DEBUG_CLIENTS --> There is no record for 2c:<redacted>7 in the client table
2025-05-21 12:56:23.495 DEBUG_CLIENTS Querying gravity database for host name of 192.168.88.3...
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> Querying client table for pi.hole
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> There is no record for pi.hole in the client table
2025-05-21 12:56:23.496 DEBUG_CLIENTS Querying gravity database for interface of 192.168.88.3...
2025-05-21 12:56:23.496 DEBUG_CLIENTS Querying client table for interface :wlan0
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> There is no record for interface :wlan0 in the client table
2025-05-21 12:56:23.496 DEBUG_CLIENTS Gravity database: Client pi.hole not found. Using default group.
2025-05-21 12:56:23.496 DEBUG_CLIENTS Reloading client groups after 529 seconds (2nd check)
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> No record for 192.168.88.3 in the client table
2025-05-21 12:56:23.496 DEBUG_CLIENTS Querying gravity database for MAC address of 192.168.88.3...
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> Querying client table for 2c:<redacted>7
2025-05-21 12:56:23.496 DEBUG_CLIENTS --> There is no record for 2c:<redacted>7 in the client table
2025-05-21 12:56:23.496 DEBUG_CLIENTS Querying gravity database for host name of 192.168.88.3...
2025-05-21 12:56:23.497 DEBUG_CLIENTS --> Querying client table for pi.hole
2025-05-21 12:56:23.497 DEBUG_CLIENTS --> There is no record for pi.hole in the client table
2025-05-21 12:56:23.497 DEBUG_CLIENTS Querying gravity database for interface of 192.168.88.3...
2025-05-21 12:56:23.497 DEBUG_CLIENTS Querying client table for interface :wlan0
2025-05-21 12:56:23.497 DEBUG_CLIENTS --> There is no record for interface :wlan0 in the client table
2025-05-21 12:56:23.497 DEBUG_CLIENTS Gravity database: Client pi.hole not found. Using default group.
2025-05-21 12:56:23.497 DEBUG_CLIENTS Reloading client groups after 529 seconds (3rd check)
2025-05-21 12:56:23.497 DEBUG_CLIENTS --> No record for 192.168.88.3 in the client table
2025-05-21 12:56:23.497 DEBUG_CLIENTS Querying gravity database for MAC address of 192.168.88.3...
2025-05-21 12:56:23.497 DEBUG_CLIENTS --> Querying client table for 2c:<redacted>7
2025-05-21 12:56:23.498 DEBUG_CLIENTS --> There is no record for 2c:<redacted>7 in the client table
2025-05-21 12:56:23.498 DEBUG_CLIENTS Querying gravity database for host name of 192.168.88.3...
2025-05-21 12:56:23.498 DEBUG_CLIENTS --> Querying client table for pi.hole
2025-05-21 12:56:23.498 DEBUG_CLIENTS --> There is no record for pi.hole in the client table
2025-05-21 12:56:23.498 DEBUG_CLIENTS Querying gravity database for interface of 192.168.88.3...
2025-05-21 12:56:23.498 DEBUG_CLIENTS Querying client table for interface :wlan0
2025-05-21 12:56:23.498 DEBUG_CLIENTS --> There is no record for interface :wlan0 in the client table
2025-05-21 12:56:23.498 DEBUG_CLIENTS Gravity database: Client pi.hole not found. Using default group.
2025-05-21 12:56:24.331 DEBUG_CLIENTS --> No record for 2401:7000:c254:de01:9aad:640:73f1:7dea in the client table
2025-05-21 12:56:24.331 DEBUG_CLIENTS Querying gravity database for MAC address of 2401:7000:c254:de01:9aad:640:73f1:7dea...
2025-05-21 12:56:24.331 DEBUG_CLIENTS --> Querying client table for 2c:<redacted>7
2025-05-21 12:56:24.331 DEBUG_CLIENTS --> There is no record for 2c:<redacted>7 in the client table
2025-05-21 12:56:24.331 DEBUG_CLIENTS Querying gravity database for host name of 2401:7000:c254:de01:9aad:640:73f1:7dea...
2025-05-21 12:56:24.331 DEBUG_CLIENTS --> Querying client table for pi.hole
2025-05-21 12:56:24.331 DEBUG_CLIENTS --> There is no record for pi.hole in the client table
2025-05-21 12:56:24.331 DEBUG_CLIENTS Querying gravity database for interface of 2401:7000:c254:de01:9aad:640:73f1:7dea...
2025-05-21 12:56:24.332 DEBUG_CLIENTS Querying client table for interface :wlan0
2025-05-21 12:56:24.332 DEBUG_CLIENTS --> There is no record for interface :wlan0 in the client table
2025-05-21 12:56:24.332 DEBUG_CLIENTS Gravity database: Client pi.hole not found. Using default group.
2025-05-21 12:56:24.360 DEBUG_CLIENTS --> No record for fe80::3fbc:9138:40d6:da6 in the client table
2025-05-21 12:56:24.360 DEBUG_CLIENTS Querying gravity database for MAC address of fe80::3fbc:9138:40d6:da6...
2025-05-21 12:56:24.361 DEBUG_CLIENTS --> Querying client table for 2c:<redacted>7
2025-05-21 12:56:24.361 DEBUG_CLIENTS --> There is no record for 2c:<redacted>7 in the client table
2025-05-21 12:56:24.361 DEBUG_CLIENTS Querying gravity database for host name of fe80::3fbc:9138:40d6:da6...
2025-05-21 12:56:24.361 DEBUG_CLIENTS --> Querying client table for pi.hole
2025-05-21 12:56:24.361 DEBUG_CLIENTS --> There is no record for pi.hole in the client table
2025-05-21 12:56:24.361 DEBUG_CLIENTS Querying gravity database for interface of fe80::3fbc:9138:40d6:da6...
2025-05-21 12:56:24.361 DEBUG_CLIENTS Querying client table for interface :wlan0
2025-05-21 12:56:24.361 DEBUG_CLIENTS --> There is no record for interface :wlan0 in the client table
2025-05-21 12:56:24.361 DEBUG_CLIENTS Gravity database: Client pi.hole not found. Using default group.
Your lines from FTL.log show that Pi-hole has correctly classified 192.168.88.3/pi.hole to be filtered by the default group:
Your debug log shows you've added and enabled quite a few adlists.
However, none of them is assigned to any group - the group_IDS column is empty for all of them, e.g.:
Thank you! That did seem to work, queries seem to be blocked more frequently
When testing on sites like https://adblock-tester.com/ or https://blockads.fivefilters.org/ I get a score of 43 and No ad blocking detected respectively on their sites. Not sure how great they are for testing but thought Id mention in case it should be working on them.
