Pi-Hole remote clients not working after v6 upgrade
Hi all,
Upgrade was easy and was able to access admin portal fine, slightly confused by the new layout (settings with expert mode) and a search feature would have been nice. I haven't changed any of the network ports from the original service.
I noticed that the Pi-hole remotes are no longer working on iOS or MACOS. I reset one of the remote clients and now can't get it to add. Where is the menu option in the Admin portal to generate the API key?
Many thanks
Ian
https://x.com/PiHoleRemote/status/1891946853534466256?t=tn54boKNDTpqkgVjK02_Yw&s=19
Thanks, looking forward to see what magic you have come up with...
It's a 3rd party application, so just need to wait for the developer to update it :slight_smile:
The app was updated, and I updated my pihole, but I can no longer connect to my pihole via the app.
I reached out to the developer, but just wanted to post here as this was the first Google result that popped up when I searched for the issue. So if it's happening to you too, you're not alone!
Hi yhivs, Did you have any luck getting the pihole remote app to connect to pihole?
Hiya! Yep I did. I had to update my pihole again and then update the app and it all worked after that :slight_smile:
