Pi-hole Remote App (Philly, Singularity) not working
Hey Guys,
I'm using pi-hole in a docker container on my Synology NAS.
The IP Adresse is 192.168.178.10 and the Web Interface Port ist set to 8080.
The Docker Container Network ist set to host, not bridge-mode.
I can't connect the Pi-Hole with the Apps Philly and Singularity. The normal Web Interface in Browser works fine.
Did anyone have an idea?
Thanks, Guys.
Pi-hole does not offer a Pi-hole Remote App.
You may consider to consult the maintainer of that App for support.
Just curious:
Where did yo get that Pi-hole Remote App from?
Both Apps are available in the AppStore.
https://apps.apple.com/de/app/philly-pi-hole-manager/id1512490851
https://apps.apple.com/de/app/singularity-pi-hole-manager/id1513685021
Clicking on the AppStore links above you will see there are a few reviews saying the apps are not able to connect.
They are probably outdated.
You will probably need to contact the app developers or replace the apps.
