Latest Pi-hole version running on Debian 10 VM
Ethernet gigabit attached
Pi-hole randomly stops to resolve my queries and the only way to solve this issue is a reboot.
Thank you
Also, note that spaces are illegal in host names, FTL replaced them by ~ and logged this here:
[2021-02-21 09:17:16.112 12543M] INFO: FTL escaped 3 characters in "home~assistant~bridge~523bf1._hap._tcp.local"
However, this will not have caused the issues you're seeing.
Please add
DEBUG_ALL=true
to the file /etc/pihole/pihole-FTL.conf (create if it does not exist) and run
pihole restartdns
Next time the issues happens, please include the last lines of /var/log/pihole-FTL.logand/var/log/pihole.log. This should help us getting a better picture of where/why exactly the issue happens.
Sorry for the inconvenience and thanks for your assistance!
[2021-02-25 18:08:16.876 6839M] Waiting for lock in _FTL_CNAME() (/root/project/src/dnsmasq_interface.c:342)
[2021-02-25 18:08:16.876 6839M] Obtained lock for _FTL_CNAME() (/root/project/src/dnsmasq_interface.c:342)
[2021-02-25 18:08:16.876 6839M] fra-efz.ms-acdc.office.com is known as not to be blocked
pihole.log shows that this query worked as expected:
Feb 25 18:08:16 dnsmasq[6839]: reply outlook.ha.office365.com is <CNAME> (/root/project/src/dnsmasq/cache.c:493)
Feb 25 18:08:16 dnsmasq[6839]: reply outlook.ms-acdc.office.com is <CNAME> (/root/project/src/dnsmasq/cache.c:493)
Feb 25 18:08:16 dnsmasq[6839]: reply FRA-efz.ms-acdc.office.com is 52.97.200.130 (/root/project/src/dnsmasq/cache.c:493)
Feb 25 18:08:16 dnsmasq[6839]: reply FRA-efz.ms-acdc.office.com is 40.101.80.18 (/root/project/src/dnsmasq/cache.c:493)
Feb 25 18:08:16 dnsmasq[6839]: reply FRA-efz.ms-acdc.office.com is 52.97.188.66 (/root/project/src/dnsmasq/cache.c:493)
... and that FTL continued to work afterwards by serving more queries, like:
Feb 25 18:10:32 dnsmasq[6839]: query[A] vortex.data.microsoft.com from 192.168.1.219 (/root/project/src/dnsmasq/forward.c:1631)
Feb 25 18:10:32 dnsmasq[6839]: forwarded vortex.data.microsoft.com to 84.200.69.80 (/root/project/src/dnsmasq/forward.c:600)
Next, time please also note down the time where you're seeing the issue. Somehow your two log files don't match in this sample.
edit Just to make this clear: We need the log when the issue is ongoing. Not after a restart (where it is working again). Just in case this is what you did here.
