The issue I am facing:
After restarting the host, Pi-Hole seemed to work (pihole status
and pihole restartdns
showed/worked fine, DNS resolving was operational I think). Unfortunately,
- a) no API responses were delivered
(which is why I discovered this issue at all - the Home Assistant integration complained about connection issues / no API response) - b) once logging in to the admin web interface, it showed no data at all:
(please note: as I forgot to take a screenshot, I rebuilt that image from my memory roughly one hour after the incident)
Details about my system:
- Pi 4, Raspberry Pi OS
- Latest Pi-hole versions: Pi-hole v5.17.3 / FTL v5.24 / Web Interface v5.21
I only restarted the host.
I ran pihole -r
(repair) which fixed the issue immediately (web page showing data again, API working).
Logs look fine to me (sudo cat /var/log/pihole/FTL.log | grep -c "database is locked"
gave 0
), no idea WHY Pi-Hole was not fully working (at least the API part seems to have been dead).
Before you guys complain: yes, the database still is big. Perhaps - and only perhaps - if it would be smaller, that incident would not have happened. To rule things out I'd prefer if someone could have a look at the FTL.log excerpt:
FTL.log excerpt
[2024-01-12 17:09:00.102 11018/T11043] Notice: Database size is 3625.64 MB, deleted 29 rows
[2024-01-12 17:20:00.124 11018/T11043] Notice: Database size is 3625.73 MB, deleted 39 rows
[2024-01-12 17:30:00.082 11018/T11043] Notice: Database size is 3625.80 MB, deleted 30 rows
[2024-01-12 17:37:25.462 11018M] Shutting down...
[2024-01-12 17:37:25.798 11018M] Finished final database update (stored 56 queries)
[2024-01-12 17:37:25.798 11018M] Waiting for threads to join
[2024-01-12 17:37:25.798 11018M] Thread database (0) is idle, terminating it.
[2024-01-12 17:37:25.800 11018M] Thread housekeeper (1) is idle, terminating it.
[2024-01-12 17:37:25.800 11018M] Thread DNS client (2) is idle, terminating it.
[2024-01-12 17:37:25.800 11018M] All threads joined
[2024-01-12 17:37:25.800 11018M] Joining API worker thread 0
[2024-01-12 17:37:25.800 11018M] Joining API worker thread 1
[2024-01-12 17:37:25.800 11018M] Joining API worker thread 2
[2024-01-12 17:37:25.801 11018M] Joining API worker thread 3
[2024-01-12 17:37:25.801 11018M] Joining API worker thread 4
[2024-01-12 17:37:25.977 11018M] ########## FTL terminated after 5d 17h 30m 49s (code 0)! ##########
[2024-01-12 17:37:44.329 858M] Using log file /var/log/pihole/FTL.log
[2024-01-12 17:37:44.383 858M] ########## FTL started on <Servername> ! ##########
[2024-01-12 17:37:44.387 858M] FTL branch: master
[2024-01-12 17:37:44.387 858M] FTL version: v5.24
[2024-01-12 17:37:44.387 858M] FTL commit: 01227311
[2024-01-12 17:37:44.387 858M] FTL date: 2024-01-06 16:47:56 +0000
[2024-01-12 17:37:44.387 858M] FTL user: pihole
[2024-01-12 17:37:44.387 858M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 8.3.0-2) 8.3.0
[2024-01-12 17:37:44.388 858M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2024-01-12 17:37:44.388 858M] SOCKET_LISTENING: only local
[2024-01-12 17:37:44.388 858M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2024-01-12 17:37:44.388 858M] MAXDBDAYS: max age for stored queries is 1095 days
[2024-01-12 17:37:44.388 858M] RESOLVE_IPV6: Resolve IPv6 addresses
[2024-01-12 17:37:44.388 858M] RESOLVE_IPV4: Resolve IPv4 addresses
[2024-01-12 17:37:44.389 858M] DBINTERVAL: saving to DB file every minute
[2024-01-12 17:37:44.389 858M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2024-01-12 17:37:44.389 858M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2024-01-12 17:37:44.389 858M] PRIVACYLEVEL: Set to 0
[2024-01-12 17:37:44.421 858M] IGNORE_LOCALHOST: Show queries from localhost
[2024-01-12 17:37:44.422 858M] BLOCKINGMODE: Null IPs for blocked domains
[2024-01-12 17:37:44.422 858M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2024-01-12 17:37:44.422 858M] DBIMPORT: Importing history from database
[2024-01-12 17:37:44.422 858M] PIDFILE: Using /run/pihole-FTL.pid
[2024-01-12 17:37:44.423 858M] SOCKETFILE: Using /run/pihole/FTL.sock
[2024-01-12 17:37:44.423 858M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2024-01-12 17:37:44.423 858M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2024-01-12 17:37:44.423 858M] GRAVITYDB: Using /etc/pihole/gravity.db
[2024-01-12 17:37:44.423 858M] PARSE_ARP_CACHE: Active
[2024-01-12 17:37:44.423 858M] CNAME_DEEP_INSPECT: Active
[2024-01-12 17:37:44.424 858M] DELAY_STARTUP: No delay requested.
[2024-01-12 17:37:44.424 858M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2024-01-12 17:37:44.424 858M] NICE: Set process niceness to -10 (default)
[2024-01-12 17:37:44.424 858M] MAXNETAGE: Removing IP addresses and host names from network table after 1095 days
[2024-01-12 17:37:44.425 858M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2024-01-12 17:37:44.425 858M] EDNS0_ECS: Overwrite client from ECS information
[2024-01-12 17:37:44.425 858M] REFRESH_HOSTNAMES: Periodically refreshing IPv4 names
[2024-01-12 17:37:44.433 858M] RATE_LIMIT: Rate-limiting client making more than 5000 queries in 60 seconds
[2024-01-12 17:37:44.445 858M] LOCAL_IPV4: Automatic interface-dependent detection of address
[2024-01-12 17:37:44.446 858M] LOCAL_IPV6: Automatic interface-dependent detection of address
[2024-01-12 17:37:44.446 858M] BLOCK_IPV4: Automatic interface-dependent detection of address
[2024-01-12 17:37:44.446 858M] BLOCK_IPV6: Automatic interface-dependent detection of address
[2024-01-12 17:37:44.446 858M] REPLY_ADDR4: Using IPv4 address xxx.xxx.xxx.xxx instead of automatically determined IP address
[2024-01-12 17:37:44.446 858M] SHOW_DNSSEC: Enabled, showing automatically generated DNSSEC queries
[2024-01-12 17:37:44.446 858M] MOZILLA_CANARY: Enabled
[2024-01-12 17:37:44.447 858M] PIHOLE_PTR: internal PTR generation enabled (pi.hole)
[2024-01-12 17:37:44.447 858M] ADDR2LINE: Enabled
[2024-01-12 17:37:44.447 858M] REPLY_WHEN_BUSY: Drop queries when the database is busy
[2024-01-12 17:37:44.447 858M] BLOCK_TTL: 2 seconds
[2024-01-12 17:37:44.447 858M] BLOCK_ICLOUD_PR: Enabled
[2024-01-12 17:37:44.447 858M] CHECK_LOAD: Disabled
[2024-01-12 17:37:44.447 858M] CHECK_SHMEM: Warning if shared-memory usage exceeds 90%
[2024-01-12 17:37:44.448 858M] CHECK_DISK: Warning if certain disk usage exceeds 90%
[2024-01-12 17:37:44.458 858M] Finished config file parsing
[2024-01-12 17:37:44.485 858M] Creating mutex
[2024-01-12 17:37:44.509 858M] PID of FTL process: 858
[2024-01-12 17:37:44.554 858M] Database version is 12
[2024-01-12 17:37:44.554 858M] Resizing "FTL-strings" from 40960 to (81920 * 1) == 81920 (/dev/shm: 1.2MB used, 2.0GB total, FTL uses 1.2MB)
[2024-01-12 17:37:44.559 858M] Imported 0 alias-clients
[2024-01-12 17:37:44.559 858M] Database successfully initialized
[2024-01-12 17:37:44.679 858M] New upstream server: xxx.xxx.xxx.xxx :53 (0/1024)
[2024-01-12 17:37:44.705 858M] New upstream server: xxx.xxx.xxx.xxx :53 (1/1024)
[2024-01-12 17:37:44.960 858M] New upstream server: xxx.xxx.xxx.xxx :53 (2/1024)
[2024-01-12 17:37:45.945 858M] Resizing "FTL-queries" from 180224 to (8192 * 44) == 360448 (/dev/shm: 1.3MB used, 2.0GB total, FTL uses 1.3MB)
[2024-01-12 17:37:46.976 858M] Resizing "FTL-queries" from 360448 to (12288 * 44) == 540672 (/dev/shm: 1.4MB used, 2.0GB total, FTL uses 1.4MB)
[2024-01-12 17:37:48.166 858M] Resizing "FTL-queries" from 540672 to (16384 * 44) == 720896 (/dev/shm: 1.6MB used, 2.0GB total, FTL uses 1.6MB)
[2024-01-12 17:37:48.428 858M] Resizing "FTL-domains" from 20480 to (2048 * 20) == 40960 (/dev/shm: 1.8MB used, 2.0GB total, FTL uses 1.8MB)
[2024-01-12 17:37:48.580 858M] Resizing "FTL-queries" from 720896 to (20480 * 44) == 901120 (/dev/shm: 1.8MB used, 2.0GB total, FTL uses 1.8MB)
[2024-01-12 17:37:48.840 858M] Resizing "FTL-queries" from 901120 to (24576 * 44) == 1081344 (/dev/shm: 2.0MB used, 2.0GB total, FTL uses 2.0MB)
[2024-01-12 17:37:50.167 858M] Resizing "FTL-queries" from 1081344 to (28672 * 44) == 1261568 (/dev/shm: 2.2MB used, 2.0GB total, FTL uses 2.2MB)
[2024-01-12 17:37:50.528 858M] Resizing "FTL-queries" from 1261568 to (32768 * 44) == 1441792 (/dev/shm: 2.4MB used, 2.0GB total, FTL uses 2.4MB)
[2024-01-12 17:37:50.769 858M] Resizing "FTL-strings" from 81920 to (122880 * 1) == 122880 (/dev/shm: 2.5MB used, 2.0GB total, FTL uses 2.5MB)
[2024-01-12 17:37:50.802 858M] Resizing "FTL-queries" from 1441792 to (36864 * 44) == 1622016 (/dev/shm: 2.6MB used, 2.0GB total, FTL uses 2.6MB)
[2024-01-12 17:37:50.926 858M] Resizing "FTL-queries" from 1622016 to (40960 * 44) == 1802240 (/dev/shm: 2.8MB used, 2.0GB total, FTL uses 2.8MB)
[2024-01-12 17:37:51.063 858M] Resizing "FTL-queries" from 1802240 to (45056 * 44) == 1982464 (/dev/shm: 2.9MB used, 2.0GB total, FTL uses 2.9MB)
[2024-01-12 17:37:51.235 858M] Resizing "FTL-queries" from 1982464 to (49152 * 44) == 2162688 (/dev/shm: 3.1MB used, 2.0GB total, FTL uses 3.1MB)
[2024-01-12 17:37:51.361 858M] Resizing "FTL-queries" from 2162688 to (53248 * 44) == 2342912 (/dev/shm: 3.3MB used, 2.0GB total, FTL uses 3.3MB)
[2024-01-12 17:37:51.533 858M] Resizing "FTL-queries" from 2342912 to (57344 * 44) == 2523136 (/dev/shm: 3.5MB used, 2.0GB total, FTL uses 3.5MB)
[2024-01-12 17:37:51.670 858M] Resizing "FTL-queries" from 2523136 to (61440 * 44) == 2703360 (/dev/shm: 3.7MB used, 2.0GB total, FTL uses 3.7MB)
[2024-01-12 17:37:51.820 858M] Resizing "FTL-queries" from 2703360 to (65536 * 44) == 2883584 (/dev/shm: 3.9MB used, 2.0GB total, FTL uses 3.8MB)
[2024-01-12 17:37:51.972 858M] Resizing "FTL-queries" from 2883584 to (69632 * 44) == 3063808 (/dev/shm: 4.0MB used, 2.0GB total, FTL uses 4.0MB)
[2024-01-12 17:37:52.176 858M] Resizing "FTL-queries" from 3063808 to (73728 * 44) == 3244032 (/dev/shm: 4.2MB used, 2.0GB total, FTL uses 4.2MB)
[2024-01-12 17:37:52.403 858M] Resizing "FTL-queries" from 3244032 to (77824 * 44) == 3424256 (/dev/shm: 4.4MB used, 2.0GB total, FTL uses 4.4MB)
[2024-01-12 17:37:52.495 858M] Resizing "FTL-domains" from 40960 to (3072 * 20) == 61440 (/dev/shm: 4.6MB used, 2.0GB total, FTL uses 4.6MB)
[2024-01-12 17:37:52.617 858M] Resizing "FTL-queries" from 3424256 to (81920 * 44) == 3604480 (/dev/shm: 4.6MB used, 2.0GB total, FTL uses 4.6MB)
[2024-01-12 17:37:52.778 858M] Resizing "FTL-queries" from 3604480 to (86016 * 44) == 3784704 (/dev/shm: 4.8MB used, 2.0GB total, FTL uses 4.8MB)
[2024-01-12 17:37:52.919 858M] Resizing "FTL-queries" from 3784704 to (90112 * 44) == 3964928 (/dev/shm: 5.0MB used, 2.0GB total, FTL uses 4.9MB)
[2024-01-12 17:37:53.052 858M] Resizing "FTL-queries" from 3964928 to (94208 * 44) == 4145152 (/dev/shm: 5.1MB used, 2.0GB total, FTL uses 5.1MB)
[2024-01-12 17:37:53.098 858M] Imported 91752 queries from the long-term database
[2024-01-12 17:37:53.100 858M] -> Total DNS queries: 91752
[2024-01-12 17:37:53.100 858M] -> Cached DNS queries: 31446
[2024-01-12 17:37:53.101 858M] -> Forwarded DNS queries: 50002
[2024-01-12 17:37:53.101 858M] -> Blocked DNS queries: 9504
[2024-01-12 17:37:53.101 858M] -> Unknown DNS queries: 22
[2024-01-12 17:37:53.101 858M] -> Unique domains: 2196
[2024-01-12 17:37:53.101 858M] -> Unique clients: XXX
[2024-01-12 17:37:53.101 858M] -> Known forward destinations: 3
[2024-01-12 17:37:53.101 858M] Successfully accessed setupVars.conf
[2024-01-12 17:37:53.111 858M] listening on 0.0.0.0 port 53
[2024-01-12 17:37:53.111 858M] listening on :: port 53
[2024-01-12 17:37:53.114 858M] PID of FTL process: 858
[2024-01-12 17:37:53.114 858M] Listening on port 4711 for incoming IPv4 telnet connections
[2024-01-12 17:37:53.115 858M] Listening on port 4711 for incoming IPv6 telnet connections
[2024-01-12 17:37:53.116 858M] Listening on port 4711 for incoming socket telnet connections
[2024-01-12 17:37:53.116 858M] INFO: FTL is running as user pihole (UID 998)
[2024-01-12 17:37:53.119 858M] Reloading DNS cache
[2024-01-12 17:37:53.511 858/T1555] Compiled 1 whitelist and 3 blacklist regex filters for 29 clients in 287.9 msec
[2024-01-12 17:37:53.513 858/T1555] Blocking status is enabled
[2024-01-12 17:37:55.128 858M] Resizing "FTL-dns-cache" from 4096 to (512 * 16) == 8192 (/dev/shm: 5.3MB used, 2.0GB total, FTL uses 5.3MB)
[2024-01-12 17:40:00.064 858/T1555] Notice: Database size is 3625.87 MB, deleted 28 rows
[2024-01-12 17:44:35.324 858M] Resizing "FTL-dns-cache" from 8192 to (768 * 16) == 12288 (/dev/shm: 6.2MB used, 2.0GB total, FTL uses 5.3MB)
[2024-01-12 17:50:00.108 858/T1555] Notice: Database size is 3625.94 MB, deleted 48 rows
[2024-01-12 17:55:30.894 858M] Resizing "FTL-queries" from 4145152 to (98304 * 44) == 4325376 (/dev/shm: 6.2MB used, 2.0GB total, FTL uses 5.3MB)
[2024-01-12 17:56:05.124 858M] Resizing "FTL-dns-cache" from 12288 to (1024 * 16) == 16384 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:00:00.109 858/T1555] Notice: Database size is 3626.01 MB, deleted 477 rows
[2024-01-12 18:06:16.625 858M] Resizing "FTL-dns-cache" from 16384 to (1280 * 16) == 20480 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:10:00.098 858/T1555] Notice: Database size is 3626.06 MB, deleted 42 rows
[2024-01-12 18:12:26.932 858M] Resizing "FTL-dns-cache" from 20480 to (1536 * 16) == 24576 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:15:02.534 858M] Resizing "FTL-dns-cache" from 24576 to (1792 * 16) == 28672 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:20:00.141 858/T1555] Notice: Database size is 3626.19 MB, deleted 159 rows
[2024-01-12 18:25:43.433 858M] Resizing "FTL-dns-cache" from 28672 to (2048 * 16) == 32768 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:28:38.685 858M] Resizing "FTL-queries" from 4325376 to (102400 * 44) == 4505600 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:28:49.575 858M] Resizing "FTL-strings" from 122880 to (163840 * 1) == 163840 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 18:28:50.800 858M] Resizing "FTL-domains" from 61440 to (4096 * 20) == 81920 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 18:30:00.117 858/T1555] Notice: Database size is 3626.26 MB, deleted 43 rows
[2024-01-12 18:32:55.717 858M] Resizing "FTL-dns-cache" from 32768 to (2304 * 16) == 36864 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.8MB)
[2024-01-12 18:34:45.617 858M] Shutting down...
[2024-01-12 18:34:45.905 858M] Finished final database update (stored 148 queries)
[2024-01-12 18:34:45.905 858/T1555] Terminating database thread
[2024-01-12 18:34:45.905 858M] Waiting for threads to join
[2024-01-12 18:34:45.906 858M] Thread housekeeper (1) is idle, terminating it.
[2024-01-12 18:34:45.907 858M] Thread DNS client (2) is idle, terminating it.
[2024-01-12 18:34:45.907 858M] All threads joined
[2024-01-12 18:34:45.908 858M] Joining API worker thread 0
[2024-01-12 18:34:45.908 858M] Joining API worker thread 1
[2024-01-12 18:34:45.908 858M] Joining API worker thread 2
[2024-01-12 18:34:45.908 858M] Joining API worker thread 3
[2024-01-12 18:34:45.908 858M] Joining API worker thread 4
[2024-01-12 18:34:45.926 858M] ########## FTL terminated after 57m 1s (code 0)! ##########
[2024-01-12 18:34:46.116 26054M] Using log file /var/log/pihole/FTL.log
[2024-01-12 18:34:46.116 26054M] ########## FTL started on <Servername> ! ##########
[2024-01-12 18:34:46.116 26054M] FTL branch: master
[2024-01-12 18:34:46.116 26054M] FTL version: v5.24
[2024-01-12 18:34:46.116 26054M] FTL commit: 01227311
[2024-01-12 18:34:46.117 26054M] FTL date: 2024-01-06 16:47:56 +0000
[2024-01-12 18:34:46.117 26054M] FTL user: pihole
[2024-01-12 18:34:46.117 26054M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 8.3.0-2) 8.3.0
[2024-01-12 18:34:46.117 26054M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2024-01-12 18:34:46.117 26054M] SOCKET_LISTENING: only local
[2024-01-12 18:34:46.117 26054M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2024-01-12 18:34:46.117 26054M] MAXDBDAYS: max age for stored queries is 1095 days
[2024-01-12 18:34:46.117 26054M] RESOLVE_IPV6: Resolve IPv6 addresses
[2024-01-12 18:34:46.117 26054M] RESOLVE_IPV4: Resolve IPv4 addresses
[2024-01-12 18:34:46.117 26054M] DBINTERVAL: saving to DB file every minute
[2024-01-12 18:34:46.117 26054M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2024-01-12 18:34:46.117 26054M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2024-01-12 18:34:46.117 26054M] PRIVACYLEVEL: Set to 0
[2024-01-12 18:34:46.117 26054M] IGNORE_LOCALHOST: Show queries from localhost
[2024-01-12 18:34:46.117 26054M] BLOCKINGMODE: Null IPs for blocked domains
[2024-01-12 18:34:46.117 26054M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2024-01-12 18:34:46.117 26054M] DBIMPORT: Importing history from database
[2024-01-12 18:34:46.117 26054M] PIDFILE: Using /run/pihole-FTL.pid
[2024-01-12 18:34:46.117 26054M] SOCKETFILE: Using /run/pihole/FTL.sock
[2024-01-12 18:34:46.118 26054M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2024-01-12 18:34:46.118 26054M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2024-01-12 18:34:46.118 26054M] GRAVITYDB: Using /etc/pihole/gravity.db
[2024-01-12 18:34:46.118 26054M] PARSE_ARP_CACHE: Active
[2024-01-12 18:34:46.118 26054M] CNAME_DEEP_INSPECT: Active
[2024-01-12 18:34:46.118 26054M] DELAY_STARTUP: No delay requested.
[2024-01-12 18:34:46.118 26054M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2024-01-12 18:34:46.118 26054M] NICE: Set process niceness to -10 (default)
[2024-01-12 18:34:46.118 26054M] MAXNETAGE: Removing IP addresses and host names from network table after 1095 days
[2024-01-12 18:34:46.118 26054M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2024-01-12 18:34:46.118 26054M] EDNS0_ECS: Overwrite client from ECS information
[2024-01-12 18:34:46.118 26054M] REFRESH_HOSTNAMES: Periodically refreshing IPv4 names
[2024-01-12 18:34:46.118 26054M] RATE_LIMIT: Rate-limiting client making more than 5000 queries in 60 seconds
[2024-01-12 18:34:46.118 26054M] LOCAL_IPV4: Automatic interface-dependent detection of address
[2024-01-12 18:34:46.118 26054M] LOCAL_IPV6: Automatic interface-dependent detection of address
[2024-01-12 18:34:46.118 26054M] BLOCK_IPV4: Automatic interface-dependent detection of address
[2024-01-12 18:34:46.118 26054M] BLOCK_IPV6: Automatic interface-dependent detection of address
[2024-01-12 18:34:46.118 26054M] REPLY_ADDR4: Using IPv4 address xxx.xxx.xxx.xxx instead of automatically determined IP address
[2024-01-12 18:34:46.119 26054M] SHOW_DNSSEC: Enabled, showing automatically generated DNSSEC queries
[2024-01-12 18:34:46.119 26054M] MOZILLA_CANARY: Enabled
[2024-01-12 18:34:46.119 26054M] PIHOLE_PTR: internal PTR generation enabled (pi.hole)
[2024-01-12 18:34:46.119 26054M] ADDR2LINE: Enabled
[2024-01-12 18:34:46.119 26054M] REPLY_WHEN_BUSY: Drop queries when the database is busy
[2024-01-12 18:34:46.119 26054M] BLOCK_TTL: 2 seconds
[2024-01-12 18:34:46.119 26054M] BLOCK_ICLOUD_PR: Enabled
[2024-01-12 18:34:46.119 26054M] CHECK_LOAD: Disabled
[2024-01-12 18:34:46.119 26054M] CHECK_SHMEM: Warning if shared-memory usage exceeds 90%
[2024-01-12 18:34:46.119 26054M] CHECK_DISK: Warning if certain disk usage exceeds 90%
[2024-01-12 18:34:46.119 26054M] Finished config file parsing
[2024-01-12 18:34:46.119 26054M] Creating mutex
[2024-01-12 18:34:46.120 26054M] Creating mutex
[2024-01-12 18:34:46.121 26054M] PID of FTL process: 26054
[2024-01-12 18:34:46.123 26054M] Database version is 12
[2024-01-12 18:34:46.123 26054M] Resizing "FTL-strings" from 40960 to (81920 * 1) == 81920 (/dev/shm: 2.1MB used, 2.0GB total, FTL uses 1.2MB)
[2024-01-12 18:34:46.138 26054M] Imported 0 alias-clients
[2024-01-12 18:34:46.138 26054M] Database successfully initialized
[2024-01-12 18:34:46.151 26054M] New upstream server: xxx.xxx.xxx.xxx :53 (0/1024)
[2024-01-12 18:34:46.152 26054M] New upstream server: xxx.xxx.xxx.xxx :53 (1/1024)
[2024-01-12 18:34:46.160 26054M] New upstream server: xxx.xxx.xxx.xxx :53 (2/1024)
[2024-01-12 18:34:46.230 26054M] Resizing "FTL-queries" from 180224 to (8192 * 44) == 360448 (/dev/shm: 2.1MB used, 2.0GB total, FTL uses 1.3MB)
[2024-01-12 18:34:46.304 26054M] Resizing "FTL-queries" from 360448 to (12288 * 44) == 540672 (/dev/shm: 2.3MB used, 2.0GB total, FTL uses 1.4MB)
[2024-01-12 18:34:46.370 26054M] Resizing "FTL-domains" from 20480 to (2048 * 20) == 40960 (/dev/shm: 2.5MB used, 2.0GB total, FTL uses 1.6MB)
[2024-01-12 18:34:46.392 26054M] Resizing "FTL-queries" from 540672 to (16384 * 44) == 720896 (/dev/shm: 2.5MB used, 2.0GB total, FTL uses 1.6MB)
[2024-01-12 18:34:46.464 26054M] Resizing "FTL-queries" from 720896 to (20480 * 44) == 901120 (/dev/shm: 2.7MB used, 2.0GB total, FTL uses 1.8MB)
[2024-01-12 18:34:46.591 26054M] Resizing "FTL-queries" from 901120 to (24576 * 44) == 1081344 (/dev/shm: 2.9MB used, 2.0GB total, FTL uses 2.0MB)
[2024-01-12 18:34:46.678 26054M] Resizing "FTL-queries" from 1081344 to (28672 * 44) == 1261568 (/dev/shm: 3.1MB used, 2.0GB total, FTL uses 2.2MB)
[2024-01-12 18:34:46.720 26054M] Resizing "FTL-queries" from 1261568 to (32768 * 44) == 1441792 (/dev/shm: 3.2MB used, 2.0GB total, FTL uses 2.4MB)
[2024-01-12 18:34:46.762 26054M] Resizing "FTL-queries" from 1441792 to (36864 * 44) == 1622016 (/dev/shm: 3.4MB used, 2.0GB total, FTL uses 2.5MB)
[2024-01-12 18:34:46.806 26054M] Resizing "FTL-queries" from 1622016 to (40960 * 44) == 1802240 (/dev/shm: 3.6MB used, 2.0GB total, FTL uses 2.7MB)
[2024-01-12 18:34:46.860 26054M] Resizing "FTL-strings" from 81920 to (122880 * 1) == 122880 (/dev/shm: 3.8MB used, 2.0GB total, FTL uses 2.9MB)
[2024-01-12 18:34:46.863 26054M] Resizing "FTL-queries" from 1802240 to (45056 * 44) == 1982464 (/dev/shm: 3.8MB used, 2.0GB total, FTL uses 2.9MB)
[2024-01-12 18:34:46.911 26054M] Resizing "FTL-queries" from 1982464 to (49152 * 44) == 2162688 (/dev/shm: 4.0MB used, 2.0GB total, FTL uses 3.1MB)
[2024-01-12 18:34:46.948 26054M] Resizing "FTL-queries" from 2162688 to (53248 * 44) == 2342912 (/dev/shm: 4.2MB used, 2.0GB total, FTL uses 3.3MB)
[2024-01-12 18:34:46.982 26054M] Resizing "FTL-queries" from 2342912 to (57344 * 44) == 2523136 (/dev/shm: 4.4MB used, 2.0GB total, FTL uses 3.5MB)
[2024-01-12 18:34:47.017 26054M] Resizing "FTL-queries" from 2523136 to (61440 * 44) == 2703360 (/dev/shm: 4.5MB used, 2.0GB total, FTL uses 3.7MB)
[2024-01-12 18:34:47.052 26054M] Resizing "FTL-queries" from 2703360 to (65536 * 44) == 2883584 (/dev/shm: 4.7MB used, 2.0GB total, FTL uses 3.8MB)
[2024-01-12 18:34:47.094 26054M] Resizing "FTL-queries" from 2883584 to (69632 * 44) == 3063808 (/dev/shm: 4.9MB used, 2.0GB total, FTL uses 4.0MB)
[2024-01-12 18:34:47.160 26054M] Resizing "FTL-queries" from 3063808 to (73728 * 44) == 3244032 (/dev/shm: 5.1MB used, 2.0GB total, FTL uses 4.2MB)
[2024-01-12 18:34:47.211 26054M] Resizing "FTL-domains" from 40960 to (3072 * 20) == 61440 (/dev/shm: 5.3MB used, 2.0GB total, FTL uses 4.4MB)
[2024-01-12 18:34:47.220 26054M] Resizing "FTL-queries" from 3244032 to (77824 * 44) == 3424256 (/dev/shm: 5.3MB used, 2.0GB total, FTL uses 4.4MB)
[2024-01-12 18:34:47.257 26054M] Resizing "FTL-queries" from 3424256 to (81920 * 44) == 3604480 (/dev/shm: 5.5MB used, 2.0GB total, FTL uses 4.6MB)
[2024-01-12 18:34:47.298 26054M] Resizing "FTL-queries" from 3604480 to (86016 * 44) == 3784704 (/dev/shm: 5.6MB used, 2.0GB total, FTL uses 4.8MB)
[2024-01-12 18:34:47.333 26054M] Resizing "FTL-queries" from 3784704 to (90112 * 44) == 3964928 (/dev/shm: 5.8MB used, 2.0GB total, FTL uses 4.9MB)
[2024-01-12 18:34:47.390 26054M] Resizing "FTL-queries" from 3964928 to (94208 * 44) == 4145152 (/dev/shm: 6.0MB used, 2.0GB total, FTL uses 5.1MB)
[2024-01-12 18:34:47.455 26054M] Resizing "FTL-queries" from 4145152 to (98304 * 44) == 4325376 (/dev/shm: 6.2MB used, 2.0GB total, FTL uses 5.3MB)
[2024-01-12 18:34:47.508 26054M] Imported 97836 queries from the long-term database
[2024-01-12 18:34:47.510 26054M] -> Total DNS queries: 97836
[2024-01-12 18:34:47.510 26054M] -> Cached DNS queries: 35480
[2024-01-12 18:34:47.510 26054M] -> Forwarded DNS queries: 51642
[2024-01-12 18:34:47.510 26054M] -> Blocked DNS queries: 9902
[2024-01-12 18:34:47.510 26054M] -> Unknown DNS queries: 24
[2024-01-12 18:34:47.510 26054M] -> Unique domains: 2971
[2024-01-12 18:34:47.510 26054M] -> Unique clients: XXX
[2024-01-12 18:34:47.510 26054M] -> Known forward destinations: 3
[2024-01-12 18:34:47.510 26054M] Successfully accessed setupVars.conf
[2024-01-12 18:34:47.512 26054M] listening on 0.0.0.0 port 53
[2024-01-12 18:34:47.512 26054M] listening on :: port 53
[2024-01-12 18:34:47.513 26054M] PID of FTL process: 26054
[2024-01-12 18:34:47.513 26054M] Listening on port 4711 for incoming IPv4 telnet connections
[2024-01-12 18:34:47.514 26054M] Listening on port 4711 for incoming IPv6 telnet connections
[2024-01-12 18:34:47.514 26054M] Listening on port 4711 for incoming socket telnet connections
[2024-01-12 18:34:47.515 26054M] INFO: FTL is running as user pihole (UID 998)
[2024-01-12 18:34:47.515 26054M] Reloading DNS cache
[2024-01-12 18:34:47.681 26054/T26073] Compiled 1 whitelist and 3 blacklist regex filters for 29 clients in 63.3 msec
[2024-01-12 18:34:47.681 26054/T26073] Blocking status is enabled
[2024-01-12 18:34:49.590 26054M] Resizing "FTL-dns-cache" from 4096 to (512 * 16) == 8192 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:36:58.702 26054M] Resizing "FTL-queries" from 4325376 to (102400 * 44) == 4505600 (/dev/shm: 6.4MB used, 2.0GB total, FTL uses 5.5MB)
[2024-01-12 18:38:42.205 26054M] Resizing "FTL-domains" from 61440 to (4096 * 20) == 81920 (/dev/shm: 6.5MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 18:40:00.038 26054/T26073] Notice: Database size is 3626.36 MB, deleted 28 rows
[2024-01-12 18:40:01.930 26054M] Resizing "FTL-dns-cache" from 8192 to (768 * 16) == 12288 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 18:40:34.422 26054M] Resizing "FTL-strings" from 122880 to (163840 * 1) == 163840 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 18:45:25.611 26054M] Resizing "FTL-dns-cache" from 12288 to (1024 * 16) == 16384 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
please note:
- masked only few things ("XXX")
- time codes for reference:
- restarted host @ 2024-01-12 17:37:XX
- ran
pihole -r
@ 2024-01-12 18:34:XX
Only potentially suspicious thing looking at the full FTL.log is: before the host restart "Resizing ..." entries only happened rarely, only every few hours. Since the incident and repair, it is logged much more frequently:
[2024-01-12 19:23:51.086 9189M] Resizing "FTL-queries" from 4505600 to (106496 * 44) == 4685824 (/dev/shm: 6.6MB used, 2.0GB total, FTL uses 5.7MB)
[2024-01-12 19:24:56.444 9189M] Resizing "FTL-dns-cache" from 8192 to (768 * 16) == 12288 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:29:55.941 9189M] Resizing "FTL-domains" from 81920 to (5120 * 20) == 102400 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:30:00.049 9189/T9251] Notice: Database size is 3626.81 MB, deleted 374 rows
[2024-01-12 19:33:25.421 9189M] Resizing "FTL-dns-cache" from 12288 to (1024 * 16) == 16384 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:40:00.116 9189/T9251] Notice: Database size is 3626.87 MB, deleted 646 rows
[2024-01-12 19:42:24.498 9189M] Resizing "FTL-dns-cache" from 16384 to (1280 * 16) == 20480 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:47:57.809 9189M] Resizing "FTL-dns-cache" from 20480 to (1536 * 16) == 24576 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:48:20.364 9189M] Resizing "FTL-strings" from 163840 to (204800 * 1) == 204800 (/dev/shm: 6.8MB used, 2.0GB total, FTL uses 5.9MB)
[2024-01-12 19:50:00.050 9189/T9251] Notice: Database size is 3626.92 MB, deleted 298 rows
[2024-01-12 19:55:10.359 9189M] Resizing "FTL-dns-cache" from 24576 to (1792 * 16) == 28672 (/dev/shm: 6.9MB used, 2.0GB total, FTL uses 6.0MB)
[2024-01-12 20:00:00.137 9189/T9251] Notice: Database size is 3626.98 MB, deleted 934 rows
