Pi-hole only works on itself
Expected pi-hole to work from anther system on LAN
Yes I haven't changed dhcp to assign pihole ip, as it is not working yet, checking with nslookup from a different system on LAN
This is fresh installation of Ubuntu and the first thing installed on it is pi-hole.
Stopped iptables service and even added ports 53 and 80 to INPUT
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.1 LTS
Release:        22.04
Codename:       jammy
ip route show
default via 10.0.0.1 dev enp0s3 proto dhcp src 10.0.0.229 metric 100
10.0.0.0/24 dev enp0s3 proto kernel scope link src 10.0.0.229 metric 100
10.0.0.1 dev enp0s3 proto dhcp scope link src 10.0.0.229 metric 100
169.254.169.254 via 10.0.0.1 dev enp0s3 proto dhcp src 10.0.0.229 metric 100
ip addr show
    inet6 ::1/128 scope host
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 02:00:17:00:12:47 brd ff:ff:ff:ff:ff:ff
    inet 10.0.0.229/24 metric 100 brd 10.0.0.255 scope global enp0s3
    inet6 fe80::17ff:fe00:1247/64 scope link
sudo iptables -A INPUT -p udp --dport 53 -j ACCEPT
sudo iptables -A INPUT -p tcp --dport 80 -j ACCEPT
sudo iptables -L INPUT
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     udp  --  anywhere             anywhere             udp spt:ntp
ACCEPT     tcp  --  anywhere             anywhere             state NEW tcp dpt:ssh
REJECT     all  --  anywhere             anywhere             reject-with icmp-host-prohibited
ACCEPT     udp  --  anywhere             anywhere             udp dpt:domain
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http
service iptables status
○ iptables.service - netfilter persistent configuration
     Loaded: loaded (/lib/systemd/system/iptables.service; alias)
     Active: inactive (dead) since Wed 2022-10-19 16:06:38 UTC; 30min ago
       Docs: man:netfilter-persistent(8)
    Process: 12841 ExecStart=/usr/sbin/netfilter-persistent start (code=exited, status=0/SUCCESS)
    Process: 12858 ExecStop=/usr/sbin/netfilter-persistent stop (code=exited, status=0/SUCCESS)
   Main PID: 12841 (code=exited, status=0/SUCCESS)
        CPU: 3ms
Oct 19 16:06:32 pi-ampere-rt1 systemd[1]: Starting netfilter persistent configuration...
Oct 19 16:06:32 pi-ampere-rt1 netfilter-persistent[12843]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/15-ip4tables start
Oct 19 16:06:32 pi-ampere-rt1 netfilter-persistent[12843]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
Oct 19 16:06:32 pi-ampere-rt1 systemd[1]: Finished netfilter persistent configuration.
Oct 19 16:06:38 pi-ampere-rt1 systemd[1]: Stopping netfilter persistent configuration...
Oct 19 16:06:38 pi-ampere-rt1 netfilter-persistent[12858]: /usr/sbin/netfilter-persistent: 39: [: -gt: unexpected operator
Oct 19 16:06:38 pi-ampere-rt1 netfilter-persistent[12858]: Automatic flush disabled; use '/usr/sbin/netfilter-persistent flush'
Oct 19 16:06:38 pi-ampere-rt1 systemd[1]: iptables.service: Deactivated successfully.
Oct 19 16:06:38 pi-ampere-rt1 systemd[1]: Stopped netfilter persistent configuration.
sudo ufw status
Status: inactive
OS seems to listen on ports 53 and 80 but does not respond form another system on LAN. Only thing working is ssh or ping from another system on lan.
Nslookup from another system
ip route show
default via 10.0.0.1 dev ens3 proto dhcp metric 100
10.0.0.0/24 dev ens3 proto kernel scope link src 10.0.0.12 metric 100
169.254.0.0/16 dev ens3 proto dhcp scope link metric 100
 ip addr show
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc fq_codel state UP group default qlen 1000
    link/ether 02:00:17:00:82:3a brd ff:ff:ff:ff:ff:ff
    inet 10.0.0.12/24 brd 10.0.0.255 scope global dynamic noprefixroute ens3
       valid_lft 53400sec preferred_lft 53400sec
    inet6 fe80::17ff:fe00:823a/64 scope link noprefixroute
 nslookup
> server 10.0.0.229
Default server: 10.0.0.229
Address: 10.0.0.229#53
> yahoo.com
> server 10.0.0.229
> google.com
https://tricorder.pi-hole.net/fM9GJk5f/
What device on your network is the DHCP server? The Pi-hole DHCP discovery found nothing:
   Timeout: 10 seconds
   DHCP packets received on interface enp0s3: 0
For the Pi, what is the basis for assigning an APIPA IP for the nameserver?
lrwxrwxrwx 1 root root 39 Aug 10 12:29 /etc/resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
   nameserver 169.254.169.254
From the Pi terminal, what is the output of the following:
nslookup pi-hole.net 127.0.0.1
nslookup pi-hole.net 10.0.0.229
not sure what helped, uninstalled ufw and iptables and a few reboots is what I can recall.
Also re-added ufw back after it was working
nslookup from pi was working though for both 127.0.0.1 and 10.0.229
