Pi-hole only briefly works after reboot
[Blocking majority of ads]
[Blocks some ads after reboot]
[ui57aw9rf9]
Pi-hole set up as DHCP aswell as DSN override enabled in router, pointing towards Pi. Query list does not update.
According to your log, things seem to be working. I see your on Jessie with v2.76 of dnsmasq. Did you follow this?
See also:
I've gone ahead and updated to FTL, at this point it seems as if my devices are ignoring the DNS at will, even tho the pi is acting as the DHCP. I've attempted to have my devices directly select the dns as per the pi's IP but that has come to no avail aswell.
New debug token: xpqmn843gm
So manually setting a device to use Pi-hole for DNS doesn't work? Is that what I understand?
