The issue I am facing:
Working on a new; I am new; to Pi-Hole. Installed on a Multi-NIC QNAP box on Unraid. I installed and 2 key issues I would like to find solutions to.
All details of how to access Pi-Hole UI is to install Tailscale ONTO the Pi running Pi-Hole. What are the steps if the Pi-Hole is running in a Docker, where it has a unique IP that is NOT a Tailscale IP.
Step 3 says to add the Tailscale IP to the NameServer of Tailscale.
Thanks!
Details about my system:
Qnap box running Unraid with Docker. All apps hosted in Docker containers. 32gb, 28TB Intel i7 (something)
Less ads on local LAN.
