Pi-hole on UDM Pro SE
I have UDM Pro SE running UniFi OS 2.3.9. How can I install Pi-hole in it?
Thanks in advance.
https://github.com/boostchicken/udm-utilities
Does it work for UDM Pro SE? as I read it only works for UDM Pro as with SE they have changed the containers.
do you have your answer ?
I have a UDMP (non SE) but SE or not it still runs Unifi OS so it's exactly the same. Only thing I did was change the DNS server on the main network, and it immediately started working.
In the release notes: Does not work on 3.x use nspawn-container
