Pi-Hole on Nginx reverse proxy
Going to pihole.domain.tld shows the web interface normally, and going to cloud.domain.tld shows the Nextcloud interface
Going to pihole.domain.tld tells me that Javascript is disabled and in the browser console I get 400 errors when resources are loading. Whenever I go to anywhere other than the root of this domain I see a Nextcloud "untrusted domain" error even though the server_name on my Nextcloud configuration is cloud.domain.tld.
lsqzubgrmx
Both domains resolve to the same IP address (I assume), so there is no difference between the two URLs. It sounds like you are trying to put both Pi-hole and Nextcloud on the same port. Change one of the ports (Nextcloud uses apache, Pi-hole uses lighttpd).
Thank you! I will go ahead with this when I have time.
