I have recently setup Pi-Hole server and intermittently the DNS look up just stops working. The browsing on the client machine (Iphone / desktop) stops working and I have to wait about 1 minute for it to start looking up websites again. This happens multiple times during the day at random times.
I have setup Pi-Hole as a docker on a Ubuntu 22.04 LTS Installation and use manual DNS configuration on the clients to connect to Pi-Hole.
My server is an Intel 12th Gen NUC with Ubuntu as the host OS. 32 GB of RAM. I also use the machine as a Plex Server / Transmission / Home Assisstant server.
I was able to capture some log when I am not able to browse from the pihole.log. Appreciate if someone can advise what is going on
Jun 12 21:41:08: query[HTTPS] stocks-data-service.apple.com from 192.168.1.220
Jun 12 21:41:08: forwarded stocks-data-service.apple.com to 208.67.222.222
Jun 12 21:41:08: query[A] stocks-data-service.apple.com from 192.168.1.220
Jun 12 21:41:08: reply stocks-data-service.apple.com is
Jun 12 21:41:08: reply stocks-data-service.lb-apple.com.akadns.net is
Jun 12 21:41:08: reply stocks-data-service.apple.com.edgesuite.net is
Jun 12 21:41:08: reply a1091.dscw154.akamai.net is 23.199.68.35
Jun 12 21:41:08: reply a1091.dscw154.akamai.net is 23.199.68.80
Jun 12 21:41:09: reply stocks-data-service.apple.com is
Jun 12 21:41:09: reply stocks-data-service.lb-apple.com.akadns.net is
Jun 12 21:41:09: reply stocks-data-service.apple.com.edgesuite.net is
Jun 12 21:41:09: reply a1091.dscw154.akamai.net is NODATA
Jun 12 21:41:09: query[A] www.ozbargain.com.au from 192.168.1.220
Jun 12 21:41:09: forwarded www.ozbargain.com.au to 208.67.222.222
Jun 12 21:41:09: reply www.ozbargain.com.au is 104.22.40.174
Jun 12 21:41:09: reply www.ozbargain.com.au is 104.22.41.174
Jun 12 21:41:09: reply www.ozbargain.com.au is 172.67.8.209
Jun 12 21:41:10: query[HTTPS] netcts.cdn-apple.com from 192.168.1.220
Jun 12 21:41:10: forwarded netcts.cdn-apple.com to 208.67.222.222
Jun 12 21:41:10: query[A] netcts.cdn-apple.com from 192.168.1.220
Jun 12 21:41:10: query[HTTPS] www.google.com from 192.168.1.220
Jun 12 21:41:10: forwarded www.google.com to 208.67.222.222
Jun 12 21:41:10: query[A] www.google.com from 192.168.1.220
Jun 12 21:41:10: reply netcts.cdn-apple.com is
Jun 12 21:41:10: reply netcts.cdn-apple.com.edgesuite.net is
Jun 12 21:41:10: reply a1744.dscw154.akamai.net is 23.199.68.24
Jun 12 21:41:10: reply a1744.dscw154.akamai.net is 23.199.68.17
Jun 12 21:41:10: reply www.google.com is 142.250.70.196
Jun 12 21:41:10: reply a1744.dscw154.akamai.net is NODATA
Jun 12 21:41:11: query[A] www.ozbargain.com.au from 192.168.1.220
Jun 12 21:41:11: forwarded www.ozbargain.com.au to 208.67.222.222
Jun 12 21:41:11: reply www.ozbargain.com.au is 172.67.8.209
Jun 12 21:41:11: reply www.ozbargain.com.au is 104.22.40.174
Jun 12 21:41:11: reply www.ozbargain.com.au is 104.22.41.174
Jun 12 21:41:13: query[HTTPS] gateway.fe.apple-dns.net from 192.168.1.229
Jun 12 21:41:13: forwarded gateway.fe.apple-dns.net to 208.67.222.222
Jun 12 21:41:13: query[A] gateway.fe.apple-dns.net from 192.168.1.229
Jun 12 21:41:13: query[SVCB] _dns.resolver.arpa from 192.168.1.229
Jun 12 21:41:13: forwarded _dns.resolver.arpa to 208.67.222.222
Jun 12 21:41:13: reply gateway.fe.apple-dns.net is NODATA
Jun 12 21:41:13: reply _dns.resolver.arpa is
That would preclude that Pi-hole has been rate-limiting your clients, or that Pi-hole's upstream DNS servers would have refused replying, at leats not recently.
You may want to analyse your log files when you encounter your observation again.
Also, Pi-hole's diagnosis should contain a respective message if rate-limiting would kick in.
Another explanation for your observation would be if Pi-hole would have been blocking the sites that a client would have requested, or if an upstream DNS server would not have answered at all.
The log excerpt you've shown above does not support those assumptions:
Instead, it confirms that Pi-hole has successfully forwarded queries upstream and received replies.
The information that you've shared so far would suggest that Pi-hole isn't involved in short inaccessibility periods of sites as observed in your client's browser.
Turning to other potential causes, the OS hosting Pi-hole may drop its network connection when entering power saving mode, specifically for wireless interfaces.
As you are running a dockered Pi-hole, information on your host machine's actual network interfaces may not be accurate in your debug log.
Would that Ubuntu machine running your Docker be connected via wifi (e.g. wlan0)?
Thank you for the reply. There is no rate limit being applied to my client. I have Pi-hole installed on my host machine (Ubuntu on NUC12) which is connected via Ethernet to the network. The NUC12 also has Wifi, but I have not connected it to the Wifi Network. There is no drop in the Host machine from the network as this behavior happens when I am actually connected and monitoring Pi-hole via web browser and I can see monitor the client request as it happens.
For e.g. this logfile was captured a few minutes ago from Pi-hole when I tried accessing the website "www.ozbargain.com.au" from my iPhone 13 (connected via WiFi) using PiHole DNS. During this time the DNS server is receiving multiple requests from my phone (IP: 192.168.1.220) but I could not receive any response on my mobile browser.
Okay I think the issue is mostly with apple devices. Since all the phones in my house are apple and they are the ones mostly impacted, I assumed it to be an overall issue with Pi-Hole.
Is there any whitelist for apple domains that may be able to fix my issue?
Yes, though strictly speaking, I was referring to the respective configuration of your Apple devices. If you are not using it (not sure, but I think its a paid Apple service), then we can disregard that as well.
I have turned off the "Private Wifi Address" on all my apple devices, way before using Pi-hole as it keeps on randomizing my mac address (if that's what you mean by the device configuration)
I have modified the pihole-FTL.conf file with the BLOCK_ICLOUD_PR=false and renewed lease to all my devices in the network. I will monitor the behavior if it solves the issue now. Will update in the morning.
Thank you for your advise @Bucking_Horn. Appreciate it loads!
