Pi Hole on Debian Not Working - dnsmasq issue possibly
I am expecting to see traffic/hits against the dashboard charts for dns queries/blocks/clients/traffic etc.
Everything shows 0's except for the blacklist domains.
My setup is a Debian 9 box (statically assigned an ip of 192.168.1.254) that is running a squid transparent web cache proxy and isc-dhcp server. I have set the dhcp server to give out this box as both the gateway and dns server ip (192.168.1.254). I have configured the box itself to use a DNS server ip of 127.0.0.1. DNS is working and I can get places online, but I can't confirm that pi hole is actually working. In fact it would appear not as everything shows 0's on the pi hole admin dashboard. I can confirm that the dnsmasq.d pi-hole conf file has the eno1 adapter listed.
Does anyone have any idea where my issue might be? If I need to provide more info I certainly can but it will take me a bit to respond as this is for a box I have at home and of course I am at work right now.
Looks like my issue might be related to dnsmasq not starting.
ancky09j9k
But it appears that dnsmasq fails to start due to port 53 already being assigned. I have not been successful in resolving. Any help is greatly appreciated.
Sounds like you have another DNS daemon/service running conflicting with dnsmasq.
Below one will display the daemon(s) listening on DNS port 53:
sudo netstat -nltup | grep "Proto\|:53 "
Have you tried starting dnsmasq manually? Somehow it seems that you might have multiple dnsmasq processes running. Try rebooting.
Ok, I ran that command and got this:
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 192.168.1.254:53 0.0.0.0:* LISTEN 646/named
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 646/named
tcp6 0 0 :::53 :::* LISTEN 646/named
udp 0 0 192.168.1.254:53 0.0.0.0:* 646/named
udp 0 0 127.0.0.1:53 0.0.0.0:* 646/named
udp6 0 0 :::53 :::* 646/named
Not sure what to make of it though.
ok, ran top and found pid 646 corresponds to bind
but not sure what to do next
ok, sorry for the repeated posts. did a quick search and just tried stopping bind9 using sudo service bind9 stop
I then tried starting dnsmasq and it worked! I immediately see info in the admin dashboard.
My question is, can I simply uninstall bind9, or possibly disable it from starting?
The man pages are a good start:
man netstat
man named
man dnsmasq
To disable named getting started at boot:
sudo systemctl disable named
ran
sudo systemctl disable bind9
all seems to be working now. thanks everyone for the help!
