I am trying to setup Pi-hole on a DO droplet with caddy and docker. But I can't access the webui.
docker-compose.yml
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
# - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
- "3148:80/tcp"
environment:
TZ: 'Asia/Kolkata'
WEBPASSWORD: 'password'
DNSMASQ_LISTENING: 'all'
VIRTUAL_HOST: 'pihole.mydomain.com'
volumes:
- './etc-pihole:/etc/pihole'
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
# cap_add:
# - NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
restart: unless-stopped
networks:
- com
networks:
com:
external: true
Caddyfile:
pihole.mydomain.com {
redir / /admin
reverse_proxy pihole:3148
Caddy docker compose file
version: "3.7"
networks:
com:
external: true
internal:
external: false
driver: bridge
services:
caddy:
container_name: caddy
image: caddy:2-alpine
ports:
- "80:80"
- "443:443"
- "443:443/udp"
volumes:
- ./:/etc/caddy
- ./data:/data
- ./config:/config
networks:
- com
- internal
This is the error from Caddy
caddy | {"level":"error","ts":1670595087.4591758,"logger":"http.log.error","msg":"dial tcp 172.18.0.3:3148: connect: connection refused","request":{"remote_ip":"202.88.249.66","remote_port":"57651","proto":"HTTP/3.0","method":"GET","host":"pihole.mydomain.com","uri":"/admin/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Priority":["u=0, i"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15"],"Accept-Language":["en-IN,en-GB;q=0.9,en;q=0.8"],"Accept-Encoding":["gzip, deflate"]},"tls":{"resumed":false,"version":0,"cipher_suite":0,"proto":"","server_name":""}},"duration":0.000771718,"status":502,"err_id":"yddjsz6gq","err_trace":"reverseproxy.statusError (reverseproxy.go:1272)"}
Any help is appreciated
