Hello! I installed Pihole through Armpibian on an Orange Pi 3 Lts. It configured everything that could be configured, including adding pi-hole DHCP server. Nothing has changed, the ads sound the same as before installation.
Your Pi-hole is configured to listen on wlan0 interface, which has no active connection. There is an active connection on the eth0 interface.
[✗] No IPv4 address(es) found on the wlan0 interface.
[✓] xxxvideo4all.blogspot.com.mt is 0.0.0.0 on lo (127.0.0.1)
[✓] xxxvideo4all.blogspot.com.mt is 0.0.0.0 on eth0 (192.168.1.175)
[✓] No IPv4 address available on wlan0
PIHOLE_INTERFACE=wlan0
Run pihole -r
and select the reconfigure option to set up Pi-hyole on the active interface and IP.
I changed from wlan to eth without any effect.
https://tricorder.pi-hole.net/XmbiTBN1/
Your router advertieses itself next to Pi-hole as DNS server. Clients will bypass Pi-hole with this configuration. You need to set Pi-hole as the only DNS server.
* Received 300 bytes from eth0:192.168.1.100
Offered IP address: 192.168.1.175
Server IP address: 192.168.1.100
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.1.100
lease-time: 86400 ( 1d )
renewal-time: 43200 ( 12h )
rebinding-time: 75600 ( 21h )
netmask: 255.255.255.0
broadcast: 192.168.1.255
wpad-server: "
dns-server: 192.168.1.175
dns-server: 192.168.1.100
Additionally, your Pi device is not able to reach a public DNS server. Do you have firewall in place?
[i] Distro: Debian
[i] Version: 11
[✗] dig return code: 9
[✗] dig response: ;; connection timed out; no servers could be reached
[✗] Error: dig command failed - Unable to check OS
Your /etc/resovl.conf
contains the IP of your router, of Pi-hole and an global IPv6. It's advisable to set a known working public DNS server there - at least until you fixed all the other issues.
