Pi-hole not working
hello everyone, since i'm having exactly the same issue
(pihole installed on raspberry pi if i get power outrage , when RPI reboot , pihole won't work and i can't access internet until i access to pihole ip 192.168.1.10 on web and restart dns resolver in settings)
i was wondering if this is the solution to this problem!!
1/ I installed ntp on the Pi.
2/ I forced "nameserver 8.8.8.8" on /etc/resolv.conf
3/ I change the right of this file to 555 to avoid system modification each time.
my pihole works as dhcp server and dns so Alexa, and any other device/pc at home won't work until i restart dns resolver manually !
thank you
Tools > Generate Debug Log
actually tonight I just had a powercut so it should be visible
(yesterday instead I made some tests so that happened quite often)
https://tricorder.pi-hole.net/4sUqB56p/
thank you :victory_hand:t2:
hello there, I didn't get any notification anymore, just wondering if you found the issue on my log?
thank you
try uploading another debug log and hopefully someone will spot it. the last one you created will no longer work
