Pi-hole not working properly
The new Debug Token: https://tricorder.pi-hole.net/g0ksu2mgxt
Seems your Pi-hole does not receive DNS packets.
Let's check if your RPi is receiving these requests at all.
We need tcpdump on your RPi machine running Pi-hole for this (click for details)
If tcpdump isn't already installed, do so by executing the following commands from an RPi terminal:
sudo apt-get update
sudo apt-get install tcpdump
From your Pi-hole RPi, execute the following:
sudo tcpdump -c 14 -n udp port 53
Then, from your Windows PC, issue the following:
nslookup www.google.com 192.168.178.46
Once issued, you should see some lines appearing on your RPi.
tcpdump will finish executing as soon as having received 14 packets (as per -c 14).
Alternatively, you can always press <CTRL> <C> to cancel execution of tcpdump.
Does tcpdump register any activities for your nslookup ?
It does register activities now. While the PC still gets time outs, this will show on the Raspberry now:
pi@raspberrypi:~ $ sudo tcpdump -c 14 -n udp port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
18:28:17.503831 IP 192.168.178.30.52065 > 192.168.178.46.53: 1+ PTR? 46.178.168.192.in-addr.arpa. (45)
18:28:19.505806 IP 192.168.178.30.52066 > 192.168.178.46.53: 2+ A? www.google.com.fritz.box. (42)
18:28:21.508378 IP 192.168.178.30.52068 > 192.168.178.46.53: 3+ AAAA? www.google.com.fritz.box. (42)
18:28:23.509524 IP 192.168.178.30.52069 > 192.168.178.46.53: 4+ A? www.google.com. (32)
18:28:25.511344 IP 192.168.178.30.52071 > 192.168.178.46.53: 5+ AAAA? www.google.com. (32)
On a network level, your RPi is receiving DNS requests from your PC.
But nothing on your RPi is reacting to these requests (as tcpdump did not register any packets for the reverse direction), which is concludent with us observing the absence of any requests in pihole.log.
I am going to run out of ideas shortly :frowning:
It seems unlikely that another DNS resolver would interfere, as we have verified earlier that port 53 was bound to pihole-FTL only.
Nonetheless: Are you aware of any other DNS resolvers running on your RPi?
And also, what is the content of your resolv.conf ?
nano /etc/resolv.conf
EDIT: And as I don't have access, it would be good to know if @jfb has spotted any anomalies in your debug log.
nameserver 127.0.0.1
This is the only one in the resolv.conf
Actually.. now that you're talking about other resolvers... Does no-ip interfere with Pi Hole?
The nameserver setting in your resolv.conf reads ok.
Mine contains the following line in additon:
search fritz.box
Not sure what you mean by no-ip.
If you are referring to the DynDNS provider of that name:
DnyDNS itself should not interfere with your Pi-hole's operation, as that is happening outside of your local network.
Yet if you have installed some client software on your RPi, it may or may not interfere. I am not familiar with that product.
No-IP is the program for DynDNS yeah. I don't think it should interfere with it though to be honest... Doesn't make sense anyway, since I can connect on my phone still.
Do you have any other clients on your network that you could run
nslookup www.google.com 192.168.178.46 from?
I can try on my father's laptop tomorrow. Apart from that there's nothing else i can test it on.
Not yet:
Maybe your firewall is dropping packets.
Did you setup firewall rules on your RPi when installing Apache webserver?
What does the following command yield on your RPi ?
sudo iptables -L
I'm not sure about the firewall rules. I did make some firewall rules, not sure if it was for apache though.
The iptables spams my console with a bunch of REJECTs:
pi@raspberrypi:~ $ sudo iptables -L
Chain INPUT (policy DROP)
target     prot opt source               destination
f2b-sshd   tcp  --  anywhere             anywhere             multiport dports ssh
ufw-before-logging-input  all  --  anywhere             anywhere
ufw-before-input  all  --  anywhere             anywhere
ufw-after-input  all  --  anywhere             anywhere
ufw-after-logging-input  all  --  anywhere             anywhere
ufw-reject-input  all  --  anywhere             anywhere
ufw-track-input  all  --  anywhere             anywhere
Chain FORWARD (policy DROP)
ufw-before-logging-forward  all  --  anywhere             anywhere
ufw-before-forward  all  --  anywhere             anywhere
ufw-after-forward  all  --  anywhere             anywhere
ufw-after-logging-forward  all  --  anywhere             anywhere
ufw-reject-forward  all  --  anywhere             anywhere
ufw-track-forward  all  --  anywhere             anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output  all  --  anywhere             anywhere
ufw-before-output  all  --  anywhere             anywhere
ufw-after-output  all  --  anywhere             anywhere
ufw-after-logging-output  all  --  anywhere             anywhere
ufw-reject-output  all  --  anywhere             anywhere
ufw-track-output  all  --  anywhere             anywhere
Chain f2b-sshd (1 references)
REJECT     all  --  96-75-59-189-static.hfc.comcastbusiness.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  pool-96-225-97-102.nwrknj.fios.verizon.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  95.9.176.177.static.ttnet.com.tr  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  static-124-118-60-95.ipcom.comunitel.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  host16-118-dynamic.251-95-r.retail.telecomitalia.it  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  dynamic-adsl-94-34-156-42.clienti.tiscali.it  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  bulgartel.bg         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  93-41-223-197.ip83.fastwebnet.it  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  104.ip-92-222-91.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  86.ip-92-222-86.eu   anywhere             reject-with icmp-port-unreachable
REJECT     all  --  91.236.116.214       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  194.33-183-91.adsl-static.isp.belgacom.be  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  91.145.17.125        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ip129.ip-91-134-145.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  qkdreyer.dev         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  90-230-32-76-no78.tbcn.telia.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  89-212-131-14.dynamic.t-2.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  89.107.129.94        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  hostby.fcloud.biz    anywhere             reject-with icmp-port-unreachable
REJECT     all  --  bou91-1_migr-88-176-68-132.fbx.proxad.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  lfbn-orl-1-1182-21.w86-244.abo.wanadoo.fr  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  host86-148-255-252.range86-148.btcentralplus.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  host86-143-133-138.range86-143.btcentralplus.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  aa75.kobe.ba.cust.gts.sk  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  c-df85e655.03-131-6c756e3.bbcust.telenor.se  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  h2832605.stratoserver.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  84-255-243-12.static.t-2.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  84-236-64-163.pool.digikabel.hu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  bzq-84-108-40-223.cablep.bezeqint.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  bpc142.neoplus.adsl.tpnet.pl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  access2.systemstats.co.uk  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  lfbn-ncy-1-282-227.w83-196.abo.wanadoo.fr  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  82.200.204.254       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  friends.place        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  50.82-134-26.bkkb.no  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  cpc116828-kemp8-2-0-cust3561.9-2.cable.virginm.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  cpc134538-amer4-2-0-cust88.know.cable.virginm.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  81.95.232.238.b2b.sarkor.uz  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  78-27-124-225.bb.dnainternet.fi  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  78.187.35.146.dynamic.ttnet.com.tr  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  primary.leadgeneration.online  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  static.kpn.net       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ip4da35d17.direct-adsl.nl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  rrcs-76-79-74-58.west.biz.rr.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  74-92-107-149-Philadelphia.hfc.comcastbusiness.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  pool-74-110-139-157.rcmdva.fios.verizon.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  c-73-63-68-254.hsd1.ut.comcast.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  c-73-168-125-223.hsd1.in.comcast.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  jnqrpq0607w-lp140-01-70-31-218-5.dsl.bell.ca  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  chowm.ceumbrolatsm.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  2.ip-66-70-191.net   anywhere             reject-with icmp-port-unreachable
REJECT     all  --  66.170.181.239       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  64.122.244.195       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ip-62-245-121-11.net.upcbroadband.cz  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  62-210-85-56.rev.poneytelecom.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  62-210-252-137.rev.poneytelecom.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  62-210-170-26.rev.poneytelecom.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  vpn2.company.local   anywhere             reject-with icmp-port-unreachable
REJECT     all  --  61.85.28.79          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  61.8.73.166          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  61.78.107.30         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  59.21.162.229        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  59.14.195.50         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  58.218.66.88         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  79.ip-51-254-219.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  050-089-051-107.res.spectrum.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  cable-5-28-64-140.cust.telecolumbus.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  5.255.68.179         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  89.ip-5-196-226.eu   anywhere             reject-with icmp-port-unreachable
REJECT     all  --  5.188.10.76          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  5.188.10.185         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  5.188.10.179         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  5.101.40.97          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  47-37-32-155.dhcp.unas.mo.charter.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  46.29.160.15         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  46.246.61.89         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  46.17.45.239         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  233797.cloudwaysapps.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  45.119.212.105       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42.7.26.61           anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42.7.26.60           anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42.7.26.49           anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42.7.26.15           anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42-2-63-100.static.netvigator.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  42-2-151-238.static.netvigator.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  40.118.29.158        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  37.49.225.93         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  37-222-96-156.red-acceso.airtel.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ec2-34-247-163-85.eu-west-1.compute.amazonaws.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ec2-34-244-135-66.eu-west-1.compute.amazonaws.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  31.28.163.34         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  23.236.125.12        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  222.187.232.39       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  221.229.204.122      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  221.140.31.7         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  220-135-98-198.HINET-IP.hinet.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  218.87.109.152       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  122.30.65.218.broad.xy.jx.dynamic.163data.com.cn  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  218.156.234.143      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  218.156.127.163      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  218.106.244.72       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  host246-5-61-217.static.arubacloud.de  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  217.160.11.159       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  212-83-168-76.rev.poneytelecom.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  211.253.8.140        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  210.56.19.88         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  209-163-172-211.static.ctl.one  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  207.96.66.252        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  206.189.94.170       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  203-154-45-96.northern.inet.co.th  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  201-048-016-201.static.algartelecom.com.br  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  201.160.179.223.cable.dyn.cableonline.com.mx  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  static.customer-201-116-201-78.uninet-ide.com.mx  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  firewall.nexchannel.cl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  server.stephan.priv.at  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  WimaxUser-197-159-222-36.vipnet.ci  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  195.3.147.49         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  150319-6201A.teremki.kiev.ua  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ptr.ruvds.com        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  194.113.106.161      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.32.163.66        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.32.163.34        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.241      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.236      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.218      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.216      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.214      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.212      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.208      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.206      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.199      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.12       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.201.224.109      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.169.124.36       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.164.7.69.static.ttnet.com.tr  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.106.29.154       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  193.105.134.97       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  192.34.60.79         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  192.207.60.26        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  191-124-40-47.bam.movistar.cl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  dslb-188-099-056-069.188.099.pools.vodafone-ip.de  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  188.92.77.235        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  188.92.75.248        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  188.92.75.240        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  bcde739b.skybroadband.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ip-188-127-4-64.ennet.pl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  187-162-20-23.static.axtel.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  dsl-187-150-231-78-dyn.prod-infinitum.com.mx  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  186.188.206.12       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  185.254.120.6        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  185.246.128.25       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  185.246.128.11       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  626l.cn              anywhere             reject-with icmp-port-unreachable
REJECT     all  --  .                    anywhere             reject-with icmp-port-unreachable
REJECT     all  --  185.110.132.49       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ip-185-108-209-125.ip.asarta.ru  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  185.100.222.110      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  static-182-18-151-5.ctrls.in  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  180.250.248.39       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  179.176.141.83.dynamic.adsl.gvt.net.br  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  179-101-95-14.user.vivozap.com.br  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  scelex.com           anywhere             reject-with icmp-port-unreachable
REJECT     all  --  178.32.61.87         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  178.162.201.79       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  178.128.212.141      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  214.17.92.177.static.copel.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  175.208.140.113      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  dynamic-adsl.viettel.vn  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  170.80.224.244       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  f8.a3.37a9.ip4.static.sl-reverse.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  163-182-175-86.static.as40244.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  163-172-127-23.rev.poneytelecom.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  162.105.28.7         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  159.65.205.44        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  159.203.36.38        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  157.157.91.93        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  unassigned.quadranet.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  mbpce-gw.customer.alter.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  151.106.12.219       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  143.ip-145-239-95.eu  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  ns538396.ip-144-217-71.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  143.225.87.198       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  142-4-4-41.unifiedlayer.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  41.141-0-98.customer.lyse.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  static.vnpt.vn       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  139.219.110.130      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  139.219.100.104      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  scan-8.security.ipip.net  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  msslab13.mss.uni-erlangen.de  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  129.213.88.157       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  129.21.105.15        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  129.205.98.180       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  76.161.185.123.broad.dl.ln.dynamic.163data.com.cn  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  122.42.23.58         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  122.32.167.22        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  121.170.3.23         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  121.132.149.181      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  120.132.102.7        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  12.178.76.78         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  117.194.100.120      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  242.12.52.116.broad.km.yn.dynamic.163data.com.cn  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  dynamic-ip-adsl.viettel.vn  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  112.33.11.22         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  customer.worldstream.nl  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  109.197.85.35        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  107.155.200.24       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  106.12.81.245        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.3.95          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.3.134         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.2.140         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.0.219         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.0.189         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.0.188         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.99.0.187         anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.89.91.227        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.89.91.207        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.89.88.218        anywhere             reject-with icmp-port-unreachable
REJECT     all  --  50.157.31.103.cni.net.id  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.207.37.217       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.207.37.142       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.207.36.187       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.114.105.79       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.114.105.38       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  103.114.104.201      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  102.165.32.158       anywhere             reject-with icmp-port-unreachable
REJECT     all  --  1.234.79.66          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  lemonplus125.cheomplus.com  anywhere             reject-with icmp-port-unreachable
REJECT     all  --  1.23.62.172          anywhere             reject-with icmp-port-unreachable
REJECT     all  --  1.100.149.252        anywhere             reject-with icmp-port-unreachable
RETURN     all  --  anywhere             anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-ns
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-dgm
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:netbios-ssn
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:microsoft-ds
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootps
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootpc
ufw-skip-to-policy-input  all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere             icmp destination-unreachable
ACCEPT     icmp --  anywhere             anywhere             icmp source-quench
ACCEPT     icmp --  anywhere             anywhere             icmp time-exceeded
ACCEPT     icmp --  anywhere             anywhere             icmp parameter-problem
ACCEPT     icmp --  anywhere             anywhere             icmp echo-request
ufw-user-forward  all  --  anywhere             anywhere
Chain ufw-before-input (1 references)
ufw-logging-deny  all  --  anywhere             anywhere             ctstate INVALID
DROP       all  --  anywhere             anywhere             ctstate INVALID
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
ufw-not-local  all  --  anywhere             anywhere
ACCEPT     udp  --  anywhere             224.0.0.251          udp dpt:mdns
ACCEPT     udp  --  anywhere             239.255.255.250      udp dpt:1900
ufw-user-input  all  --  anywhere             anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output  all  --  anywhere             anywhere
Chain ufw-logging-allow (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN     all  --  anywhere             anywhere             ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type LOCAL
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type MULTICAST
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
ufw-logging-deny  all  --  anywhere             anywhere             limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT     tcp  --  anywhere             anywhere             ctstate NEW
ACCEPT     udp  --  anywhere             anywhere             ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ssh
ACCEPT     udp  --  anywhere             anywhere             udp dpt:22
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ftp
ACCEPT     udp  --  anywhere             anywhere             udp dpt:fsp
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
ACCEPT     udp  --  anywhere             anywhere             udp dpt:443
ACCEPT     udp  --  anywhere             anywhere             udp dpt:80
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:81
ACCEPT     udp  --  anywhere             anywhere             udp dpt:81
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25565
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25565
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25566
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25566
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:9987
ACCEPT     udp  --  anywhere             anywhere             udp dpt:9987
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http-alt
ACCEPT     udp  --  anywhere             anywhere             udp dpt:http-alt
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:mysql
ACCEPT     udp  --  anywhere             anywhere             udp dpt:mysql
Chain ufw-user-limit (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
In the iptables output, I dont see any rules to allow ports 53 UDP & TCP for DNS (udp dpt:domain & tcp dpt:domain).
Try to configure the UFW firewall to also allow incoming 53 UDP + TCP for your local network only!
And when run the iptables command, better add the -n argument for numerical output so the command doesnt try to resolve all the IP's to names and displays port numbers instead of port describtions eg:
sudo iptables -L -n
Plus I notice you have fail2ban active for SSH and it banned a bunch already so you must have SSH open to the public (port forwarded on the router or something):
sudo fail2ban-client status sshd
Dont do the same port forwarding with DNS port 53 UDP or you'll be contributing to DDoS amplification attacks!
And Pi-hole might be hampered by the amount and type of DNS traffic attracted.
Okay so, i removed the SSH entry from the firewall and remade it for the local network only. I did the same for the port 53. After that i changed my router settings again to use the Pi Hole and right now it seems to work! I can access the internet on my PC and the ads i usually see are blocked as far as i noticed now.
But thank you for the help you've given so far! :slight_smile:
EDIT: I got the ad on YouTube on my PC aswell now. Could it be that they're using domains for their ads that are not in the lists yet, so that i could just block them in the admin interface?
Actually.. i think they use the same domain for the YouTube videos and their ads.. You would have to block every single ad one by one, right?
EDIT EDIT: I figured out why it didn't block on my phone. Didn't know my phone uses IPv6.
Glad we've got this sorted :slight_smile:
I try to summarize what we did during the length of this thread.
We configured your FB to distribute 192.168.178.46 as local DNS server to its DHCP clients via Heimnetz | Netzwerk | Netzwerkeinstellungen | IPv4-Adressen
We also got rid of a possible DNS loop by ensuring your FB is configured to use its default ISP-provided DNS servers as upstream DNS servers via Internet | Zugangsdaten | DNS-Server. Specifically, we removed Pi-hole from these settings, as to avoid closing the loop with your Pi-hole using your FB as one of its upstream servers.
We verified that your Pi-hole is up and running at 192.168.178.46, it is correctly configured to listen on its wlan0 interface and showing no signs of port conflicts.
However, Pi-hole still didn't register any incoming DNS requests from your Windows PC in pihole.log.
Monitoring DNS a the network level did prove that your RPi running Pi-hole received DNS packets, suggesting that something dropped these packets before they would reach Pi-hole, most likely a firewall.
Indeed, your firewall wasn't configured to allow correct handling of DNS requests.
(Thanks go to @deHakkelaar for jumping in at the late hours when I was grabbing some sleep :wink: )
Adding corresponding rules finally made your Pi-hole operational.
As a firewall on your RPi was blocking DNS traffic per se, it seems unlikely that your phone was using Pi-hole as its DNS server when it was able to resolve hostnames while your PC wasn't.
Hence, I'd suspect your phone to still bypass Pi-hole.
You might want to check your IPv6 settings in your FB.
Unfortunately, even with a correct router IPv6 configuration, it is not uncommon for phones to use your ISP-provided DNS directly.
This can be attributed to IPv6 auto configuration which allows and in fact encourages a device's network integration at the complete discretion of the device, rather than leaving it to the central authority of a DHCP server.
The amount of ads that is getting blocked will depend entirely on the blocklists and reg ex filters you chose to employ. The default lists shipping with Pi-hole already do a decent job.
If you want to expand on that, go for quality and content, not for sheer volume.
WaLLy3k’s Blocklist collection is a good starting point, and Steven Black’s hosts files do a good job in grouping blocking lists by topics.
Focus your attention on the sites you visit regularly - if they still show ads, go tune your blacklists until satisfied. After all, it’s of little use having a domain on your block list that you never visit.
If you are still seeing ads in places you visit regularly, How do I determine what domain an ad is coming from? has good insights on how to decide what sites to block.
Personally, I use a browser extension (uBO Scope ) to help me determine what sites a web page contacts and tries to contact in the background.
As for Youtube, blocking embedded ads is almost impossible, as the bulk of them is getting served by the same domain as the content.
I figured as much. As for the phone, i already fixed that. I didn't setup Pi Hole for IPv6 because i thought nothing in my network uses it anyway. But apparently my phone does. So that's setup aswell now. Also thank you for the links to the collections! I'll see if i can add them to my Pi Hole.
Thank you all so much for the help! :slight_smile:
