I tried to add the ip of the pi dhcp server (10.0.0.216) to my ipad and when I opened safari and tried to go to a website it would either not load or load and still show ads. I have xfinity by the way and the previous dns
was 75.75.75.75 , 75.75.76.76 then 2001:558:feed::1 2001:558:feed::2.
It does work on my pc though , plus this is raspberry pi 2 model b+ and connected to router via ethernet.
::: ---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71)
::: lighttpd/1.4.35
::: PHP 5.6.30-0+deb8u1 (cli) (built: Apr 14 2017 16:20:58)
::: ---= Detecting existence of /etc/pihole/setupVars.conf:
::: File exists, parsing...done and was successfully sourced
::: ---= Detecting installed OS Distribution
::: ---= Checking processor variety
::: ---= Checking IPv6 Stack
::: IPv6 addresses located on eth0
::: Pinging default IPv6 gateway: ::: Gateway responded.
::: Pinging Internet via IPv6: ::: Query responded.
::: ---= Checking IPv4 Stack
::: IPv4 addresses located on eth0
::: Pinging default IPv4 gateway: ::: Gateway did not respond.
::: ---= Daemon Process Information
::: Checking http port for lighttpd listener.
::: Correctly configured.
::: Checking domain port for dnsmasq listener.
::: Checking 4711 port for pihole-FTL listener.
::: ---= Processes Check
::: Logging status of lighttpd, dnsmasq and pihole-FTL...
::: ---= Resolver Functions Check (IPv4)
::: ---= Resolver Functions Check (IPv6)
::: Checking for necessary lighttpd files.
::: ---= Detecting existence of /etc/lighttpd/lighttpd.conf:
::: ---= Detecting existence of /var/log/lighttpd/error.log:
::: ---= Detecting existence of /etc/dnsmasq.conf:
::: ---= Detecting contents of /etc/dnsmasq.d/*:
::: ---= File /etc/dnsmasq.d/01-pihole.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/README found
::: Parsing...done
::: ---= Detecting existence of /etc/pihole/whitelist.txt:
::: ---= Detecting existence of /etc/pihole/blacklist.txt:
::: /etc/pihole/blacklist.txt not found!
::: ---= Detecting existence of /etc/pihole/adlists.list:
