Pi Hole not working after DNS fix/ Little Snitch Update/ Blacklist extension
Pi Hole should block ads
In Pi Holes Dashboard 0 Queries are Blocked and the only queries tracked are from api.github and Debian
wif5g2qlmw
Hi there, i love using my pi hole, unfortunately i have a problem with adtracking and can not really point a finger on where it is coming from as pi hole was working properly the whole time. the last time i checked, there was a problem concerning my DNS servers as pi hole was constantly deactivating itself. thanks to some reading here this problem is not existing anymore, however, since then it is not blocking or tracking any ads anymore.
the only 2 things i did that could lead to that i guess were updating little snitch to version 4 ( even though i was using it before in version 3 without problems ) and adding files to the blacklist extension.
i hope you can help me with this!
thanks a lot!
i did manage after extensive reading!
Did you find the issue? What was it?
I can not 100% pin it down as pinhole was working before without any problems. what i did that worked was to set the ip of pi-hole to 0.0.0.0, same for the ipv6 and reconfigured the pinhole as dhcp server. this worked.
