Pi-hole Not Using Unbound
Hello, I installed Unbound using this guide: unbound - Pi-hole documentation
I attached a picture of my DNS settings in the Pi-hole web interface:
When I run service --status-all, it shows that the Unbound service is running.
Running commands like dig pi-hole.net @127.0.0.1 -p 5335 also return positive results (it shows the pi-hole.net IP address).
I would expect DNS checkers like https://whoismydns.com/ to return my personal, external IP address as the DNS resolver, not Cloudflare or Google.
DNS checkers like https://whoismydns.com/ show that my DNS server is owned by either Cloudflare or Google (it looks like it changes every few times I check).
https://tricorder.pi-hole.net/2CWiguFz/
It looks like you are running Raspbian Bullseye, which puts an unwanted configuration file in the unbound folder. What is the output of the following from the Pi terminal?
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	name: "."
This is the unwanted file, which has turned unbound into a forwarding (not recursive) resolver, using Cloudflare DNS.
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	forward-addr: 1.1.1.1
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:	forward-addr: 1.0.0.1
Here's the fix.
  1. Edit file /etc/resolvconf.conf and comment out the last line which should read:
unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Restart unbound:
sudo service unbound restart
Amazing, thank you very much. It's working now.
As explained in Pihole's Unbound documentation:
Where is this specific issue explained on that page?
It isn't there, hasn't been updated yet.
