-Pi OS 64 bit (Debian GNU/Linux 10: Linux Rasberrypi 5.4.51-v8+ #1333)
-4GB Rasberry Pi Model B; 32GB Class 10 SD card
nothing is happening; I point my MacBook (Catalina) to the reserved IP for the Rasberry and DNS stops working altogether; flushing the DNS cache has no effect; I can ping the Rasberry from my Macbook and vice versa; I can run nslookup on the Rasberry against known domains; putting DNS back on the Macbook restores DNS resolution
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.1.254
* Pinging 192.168.1.254...
[i] Default IPv6 gateway: fe80::c289:abff:feb9:9620
* Pinging fe80::c289:abff:feb9:9620...
Oct 11 10:38:16 dnsmasq[814]: warning: interface eth0 does not currently exist
The Rasberry device in this context is connected wirelessly; forgive my ignorance, but is that the issue, or an issue? It's my understanding that eth0 is the wired interface.
