The issue I am facing:
I'm new to pi-hole and the issue I'm having is when trying to create dns records or save other setting via the admin web interface they are not saving.
if I add the dns via the cli inside the container
/usr/local/bin/pihole -a addcustomdns 127.0.0.1 test6.local
[✓] Adding custom DNS entry...
[✓] Restarting DNS server
That works
ls -al /var/www/html/admin/scripts/pi-hole/php/header.php
pihole status
-rw-r--r-- 1 root root 4983 Jul 6 04:19 /var/www/html/admin/scripts/pi-hole/php/header.php
[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
root@1e1693864b5e:/# sudo service dnsmasq status
s6 service not found for dnsmasq, exiting...
sudo pihole status web
53
root@1e1693864b5e:/# sudo service lighttpd status -l
up (pid 215) 44732 seconds
root@1e1693864b5e:/# ls -al /etc/sudoers.d/pihole
-r--r----- 1 root root 367 Jul 6 04:19 /etc/sudoers.d/pihole
root@1e1693864b5e:/# which pihole
root@1e1693864b5e:/# sudo service pihole-FTL status
up (pid 21738) 279 seconds
root@1e1693864b5e:/etc/pihole# ls -lh /etc/pihole/pihole-FTL.db
-rw-rw-r-- 1 pihole pihole 160K Aug 7 11:26 /etc/pihole/pihole-FTL.db
I've confirmed the volume data mataches inside and outside the container.
Details about my system:
vm on proxmox
Core OS: Ubuntu 24.04 LTS
Docker version 27.1.1, build 6312585
Docker Tag [2024.07.0]
Pi-hole [v5.18.3]
FTL [v5.25.2]
Web Interface** [v5.21] pihole_docker_yaml.txt (1.9 KB)
New install
if I view the View container logs it shows this error
sudo: effective uid is not 0, is /usr/bin/sudo on a file system with the 'nosuid' option set or an NFS file system without root privileges?
If I look inside the docker container at the logs for: /var/log/lighttpd# error-pihole.log
2024-08-06 22:37:35: server.c.1513) server started (lighttpd/1.4.59)
2024-08-06 22:39:15: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomdns 10.2.1.238 porvm01 false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 22:39:15: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:06:19: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomcname pihole.local.tribalflamingo.com porvm01.local.tribalflamingo.com false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:06:19: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:21:31: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a -i local -web failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:21:31: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a ratelimit 1000 60 false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:21:31: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a setdns "208.67.222.222,208.67.220.220" domain-not-needed no-bogus-priv no-dnssec failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-06 23:21:47: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a disabledhcp failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 10:42:19: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomdns 10.2.1.238 traefik-dashboard.local.tribalflamingo.com false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 10:42:19: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:36:20: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomcname traefik-dashboard.local.tribalflamingo.com porvm01.local.tribalflamingo.com false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:36:20: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:41:08: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomdns 127.0.0.1 test2.local false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:41:08: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:42:59: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a addcustomdns 127.0.0.1 test2.local false failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 15:42:59: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole restartdns failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 16:14:08: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a layout boxed failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
2024-08-07 16:14:34: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: Executing sudo pihole -a layout boxed failed. in /var/www/html/admin/scripts/pi-hole/php/func.php on line 173
This would prevent clients from accessing Pi-hole's UI via pi.hole, unless that access would originate from the very machine that Pi-hole is running on. Commonly, you'd point that to one of the IPs of your host system.
