Pi-Hole not receiving requests
PI-Hole recieves request on local static IP 192.168.1.55, passes on to google if not on blacklist, returns request with DNS.
Doesn't even see my devices connected, doesn't receive any DNS requests. Even though possibly an Issue with the static IP, as in my debug token it put 192.168.1.55 and added a /24 to the end?
https://tricorder.pi-hole.net/wxjylzj8wk
From your debug log:
[✓] IPv4 address(es) bound to the wlan0 interface:
   192.168.1.55/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
Run pihole -r and select reconfigure and then verify the interface and IP for Pi-Hole.
Just clarifying, when entering the dns server, you only put 192.168.1.55 not the /24
Correct?
Thanks for the help.
Yes. The /24 is the subnet mask.
