Pi-hole not receiving queries?
$ grep log-queries /etc/dnsmasq.d/01-pihole.conf
log-queries
Sorry forgot one:
grep "log-queries\|log-facility" /etc/dnsmasq.d/01-pihole.conf
then I get an additional line
dnsmasq -v
And:
stat /var/log/pihole.log
$ dnsmasq -v
Dnsmasq version 2.76  Copyright (c) 2000-2016 Simon Kelley
Compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
and
$ stat /var/log/pihole.log
  File: /var/log/pihole.log
  Size: 0         	Blocks: 0          IO Block: 4096   regular empty file
Device: 811h/2065d	Inode: 12584931    Links: 1
Access: (0644/-rw-r--r--)  Uid: (  120/ dnsmasq)   Gid: (    0/    root)
Access: 2017-12-30 16:24:43.399428023 -0800
Modify: 2017-12-30 16:24:43.255443486 -0800
Change: 2017-12-30 16:24:43.255443486 -0800
 Birth: -
sudo netstat -nltup | grep ":53 "
$ sudo netstat -nltup | grep ":53 "
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      700/dnsmasq
tcp6       0      0 :::53                   :::*                    LISTEN      700/dnsmasq
udp        0      0 172.17.0.1:53           0.0.0.0:*                           588/named
udp        0      0 10.8.0.1:53             0.0.0.0:*                           588/named
udp        0      0 192.168.1.150:53        0.0.0.0:*                           588/named
udp        0      0 127.0.0.1:53            0.0.0.0:*                           588/named
udp        0      0 0.0.0.0:53              0.0.0.0:*                           700/dnsmasq
udp6       0      0 :::53                   :::*                                588/named
udp6       0      0 :::53                   :::*                                700/dnsmasq
I almost gave up :smiley:
But you have another DNS daemon/service running called "named" answering instead of dnsmasq.
Kill that one and your good to go I hope?
sudo systemctl stop named
sudo systemctl disable named
sudo systemctl restart dnsmasq
EDIT: Ohw and check again after with below one:
dig ads.nexage.com @localhost 1> /dev/null; tail -2 /var/log/pihole.log
I hope I wasn't using named for anything.. haha. After disabling:
$ dig ads.nexage.com @localhost 1> /dev/null; tail -2 /var/log/pihole.log
Dec 30 17:14:12 dnsmasq[14851]: query[A] ads.nexage.com from ::1
Dec 30 17:14:12 dnsmasq[14851]: /etc/pihole/gravity.list ads.nexage.com is 192.168.1.150
ITS WORKING!
Welcome to ad free world :wink:
Thanks everyone and especially deHakkelaar for all your help! I really appreciate it, and I'd just like to say I'm seriously impressed on the infrastructure you've built here for support! Keep being awesome!
